Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Trouble connecting phone to Wifi
Phone will not connect to or recognize networks.
Reset the phone
From the home screen, press Menu - Backup and reset - Factory data reset - Reset phone. It may ask for a password. Then select erase everything.
Phone does not charge
The battery is broken or damaged.
Change the battery
Replace it with a manufacturer original or a respected third-party unit. In our experience though, third-party batteries are often cheaper but more trouble than they are worth, and can even be damaging to your device, so use one at your own risk.
Guide For Replacing The Battery.
Phone suddenly shuts down
Phone freezes and then shuts down.
Battery runs out quickly
Turn off applications that aren't being used. Use extended standby mode when screen is inactive to minimize battery consumption. Lower screen brightness level.
Phone freezes
All you have to do is hold the Volume Down button and then the Power key and hold these two buttons down simultaneously for about 15-20 seconds. After holding them down for about 20 seconds if the phone didn't power cycle then release the keys and try and turn the phone on like you normally would by briefly pressing the power button.
No network coverage
Doesn't connect to a network, doesn't receive calls or messages.
Signal Damaged
Make sure you have set your device to use the correct network type. If your subscription plan does not support the LTE (4G) standard, you must select a network type other than LTE (4G). If necessary, contact your operator for more information about your subscription and the network types supported.
Camera
Replacing the Camera.
Guide For Replacing The Camera.
Headphone Jack
Replacing Headphone Jack.
Guide For Replacing The Earphone jack.
Loudspeaker Module
Replacing the Loudspeaker Module.
Guide For Replacing The Loudspeaker Module.
Motherboard
Replacing the Motherboard.
Guide For Replacing The Motherboard.
Author
with
Faisal
216 Reputation
1 Guide authored
USF Tampa, Team 7-2, Leahy Fall 2014 Member of USF Tampa, Team 7-2, Leahy Fall 2014
USFT-LEAHY-F14S7G2
4 Members
60 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 1,016
