Sony Xperia U Motherboard Replacement
    1. Sony Xperia U Motherboard Replacement, Battery: step 1, image 1 of 1
      • Set the phone screen down on a clean flat, surface.
      • Insert the plastic opening tool into the groove located between the body of the phone, and the back plate protecting the battery.
      • Open the back of the device by prying around the sides of the back panel using the plastic opening tool.
      Ask FixBot
    2. Sony Xperia U Motherboard Replacement: step 2, image 1 of 1
      • Insert the plastic opening tool in between the battery and the phone body.
      • Pry up on the side of battery, and remove it.
      Ask FixBot
    1. Sony Xperia U Motherboard Replacement, Motherboard: step 3, image 1 of 1
      • Remove the bottom cover of the phone using the plastic opening tool.
      Ask FixBot
    2. Sony Xperia U Motherboard Replacement: step 4, image 1 of 1
      • Remove the five 5.47mm and one 5.18mm Torx head screws using a Phillips #0 screwdriver.
      Ask FixBot
    3. Sony Xperia U Motherboard Replacement: step 5, image 1 of 1
      • Carefully remove the back cover using the plastic opening tool.
      Ask FixBot
    4. Sony Xperia U Motherboard Replacement: step 6, image 1 of 1
      • Pry up on the right side of the motherboard using the plastic opening tool.
      Ask FixBot
    5. Sony Xperia U Motherboard Replacement: step 7, image 1 of 1
      Tool used on this step:
      Buy
      • Carefully detach the flex cable using a pair of tweezers.
      Ask FixBot
3 other people completed this guide.
Bader
545 Reputation
4 Guides authored
USF Tampa, Team 7-2, Leahy Fall 2014 Member of USF Tampa, Team 7-2, Leahy Fall 2014
USFT-LEAHY-F14S7G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 34
All Time: 3,337
