Page Stub
This wiki page is a stub. Help us improve this page by adding information to it!
Screen issues
Screen is cracked
Your screen is simply cracked and needs to be replaced.
Purchasing a new screen will have to be necessary , however reserving all of the old parts is a possibility. Here is the screen/digitizer replacement guide.
Touch screen is not functioning properly
Either the phone does not respond at all to touch or it only sometimes works.
The battery harness could be the source of the problem, or if the digitizer was broken then a new screen setup would have to be replaced.
Phone will not turn on
Drained/bad battery
Your battery needs to be replaced.
We all know that sometimes our battery quits working to replace the batery, check out the battery replacement guide.
Sound issues
Sound does not come out of the headphones partially or at all
The headphone jack may be damaged or disconnected. It may either need to be replaced or reconnected.
Sound does not come out of the speaker or it sounds abnormal
The speaker needs to be replaced in order to revert back to normal sound.
Author
with
Nathan Laneau
435 Reputation
2 Guides authored
USF Tampa, Team 4-4, Brown Fall 2014 Member of USF Tampa, Team 4-4, Brown Fall 2014
USFT-BROWN-F14S4G4
3 Members
120 Guides authored
2 Comments
You need subheadings for each heading to reflect multiple possible solutions.
Dan Brown - Reply Share
This page should contain links to repair guides.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 22
All Time: 731
