Sony Xperia TL Battery Harness Replacement
    1. Sony Xperia TL Battery Harness Replacement, Remove Top Plastic Section: step 1, image 1 of 3 Sony Xperia TL Battery Harness Replacement, Remove Top Plastic Section: step 1, image 2 of 3 Sony Xperia TL Battery Harness Replacement, Remove Top Plastic Section: step 1, image 3 of 3
      • Use the plastic opening tool to pry the top plastic section off.
      Ask FixBot
    2. Sony Xperia TL Battery Harness Replacement, Remove Bottom Plastic Section: step 2, image 1 of 2 Sony Xperia TL Battery Harness Replacement, Remove Bottom Plastic Section: step 2, image 2 of 2
      • Use the plastic opening tool to pry the bottom plastic section off.
      Ask FixBot
    3. Sony Xperia TL Battery Harness Replacement, Unscrewing the Back Off: step 3, image 1 of 3 Sony Xperia TL Battery Harness Replacement, Unscrewing the Back Off: step 3, image 2 of 3 Sony Xperia TL Battery Harness Replacement, Unscrewing the Back Off: step 3, image 3 of 3
      • Remove the four 5mm screws.
      • Use the plastic opening tool to pry off the back.
      Ask FixBot
    1. Sony Xperia TL Battery Harness Replacement, Loud Speaker: step 4, image 1 of 3 Sony Xperia TL Battery Harness Replacement, Loud Speaker: step 4, image 2 of 3 Sony Xperia TL Battery Harness Replacement, Loud Speaker: step 4, image 3 of 3
      • Use the plastic opening tool to remove the loud speaker module.
      Ask FixBot
    1. Sony Xperia TL Battery Harness Replacement, Auxiliary Cord: step 5, image 1 of 2 Sony Xperia TL Battery Harness Replacement, Auxiliary Cord: step 5, image 2 of 2
      • Use the plastic opening tool to unlatch the cord's ends off the motherboard and loud speaker module. The cord can be located on the right side of the phone.
      Ask FixBot
    1. Sony Xperia TL Battery Harness Replacement, Battery Harness: step 6, image 1 of 3 Sony Xperia TL Battery Harness Replacement, Battery Harness: step 6, image 2 of 3 Sony Xperia TL Battery Harness Replacement, Battery Harness: step 6, image 3 of 3
      • Unhook the 2 connections between the harness and phone shell.
      • Using the plastic opening tool, pry the harness up and remove it.
      • There is an adhesive on the bottom half of the battery harness.
      Ask FixBot
    2. Sony Xperia TL Battery Harness Replacement: step 7, image 1 of 1
      • The final step is taking the entire harness off of the phone.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Adam Giniger
1,303 Reputation
8 Guides authored
USF Tampa, Team 4-4, Brown Fall 2014 Member of USF Tampa, Team 4-4, Brown Fall 2014
USFT-BROWN-F14S4G4
3 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 24
All Time: 690
