Up to 20% off select tools
Sony Xperia TL Display Assembly Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
12
Past 30 Days:
87
All Time:
1,198
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Parts
Tools
Introduction
Go to step 1 ↓
I will teach the guide reader how to access this piece and to replace it, it must be purchased.
    1. Sony Xperia TL Display Assembly Replacement, Remove Top Plastic Section: step 1, image 1 of 3 Sony Xperia TL Display Assembly Replacement, Remove Top Plastic Section: step 1, image 2 of 3 Sony Xperia TL Display Assembly Replacement, Remove Top Plastic Section: step 1, image 3 of 3
      • Use the plastic opening tool to pry the top plastic section off.
      Ask FixBot
    2. Sony Xperia TL Display Assembly Replacement, Remove Bottom Plastic Section: step 2, image 1 of 2 Sony Xperia TL Display Assembly Replacement, Remove Bottom Plastic Section: step 2, image 2 of 2
      • Use the plastic opening tool to pry the bottom plastic section off.
      Ask FixBot
    3. Sony Xperia TL Display Assembly Replacement, Unscrewing the Back Off: step 3, image 1 of 3 Sony Xperia TL Display Assembly Replacement, Unscrewing the Back Off: step 3, image 2 of 3 Sony Xperia TL Display Assembly Replacement, Unscrewing the Back Off: step 3, image 3 of 3
      • Remove the four 5mm screws.
      • Use the plastic opening tool to pry off the back.
      Ask FixBot
    1. Sony Xperia TL Display Assembly Replacement, Loud Speaker: step 4, image 1 of 3 Sony Xperia TL Display Assembly Replacement, Loud Speaker: step 4, image 2 of 3 Sony Xperia TL Display Assembly Replacement, Loud Speaker: step 4, image 3 of 3
      • Use the plastic opening tool to remove the loud speaker module.
      Ask FixBot
    1. Sony Xperia TL Display Assembly Replacement, Battery: step 5, image 1 of 3 Sony Xperia TL Display Assembly Replacement, Battery: step 5, image 2 of 3 Sony Xperia TL Display Assembly Replacement, Battery: step 5, image 3 of 3
      • Use the plastic opening tool to detach the ribbon running across the battery.
      • Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
      Ask FixBot
    1. Sony Xperia TL Display Assembly Replacement, Battery Harness: step 6, image 1 of 3 Sony Xperia TL Display Assembly Replacement, Battery Harness: step 6, image 2 of 3 Sony Xperia TL Display Assembly Replacement, Battery Harness: step 6, image 3 of 3
      • Unhook the 2 connections between the harness and phone shell.
      • Using the plastic opening tool, pry the harness up and remove it.
      • There is an adhesive on the bottom half of the battery harness.
      Ask FixBot
    2. Sony Xperia TL Display Assembly Replacement: step 7, image 1 of 1
      • The final step is taking the entire harness off of the phone.
      Ask FixBot
    1. Sony Xperia TL Display Assembly Replacement, Motherboard: step 8, image 1 of 3 Sony Xperia TL Display Assembly Replacement, Motherboard: step 8, image 2 of 3 Sony Xperia TL Display Assembly Replacement, Motherboard: step 8, image 3 of 3
      • Use the Phillips #00 to remove the 3 5mm screws.
      • Lift the plastic cover off.
      • Use the plastic opening tool to pry the motherboard out of the phone shell.
      Ask FixBot
    1. Sony Xperia TL Display Assembly Replacement, Ear Speaker: step 9, image 1 of 1
      • Use the plastic opening tool to detach the ear piece speaker.
      • Avoid majorly bending the tiny metal hooks holding the ear piece in.
      Ask FixBot
    1. Sony Xperia TL Display Assembly Replacement, Display Assembly: step 10, image 1 of 1
      • Once every single piece is removed from the main screen/digitizer this will be the only remaining piece. Nothing else can be removed. If you need to replace your screen this entire piece must be replaced.
      Ask FixBot
Author
with
Adam Giniger
1,303 Reputation
8 Guides authored
USF Tampa, Team 4-4, Brown Fall 2014 Member of USF Tampa, Team 4-4, Brown Fall 2014
USFT-BROWN-F14S4G4
3 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 87
All Time: 1,198
