The DVD player is not reading the DVD
The DVD player is not sensing a CD or DVD after it is inserted.
DVD reader is blocked or broken
If the DVD player is not registering any DVD or CD after being inserted into the disk drawer, then the DVD reader may be malfunctioning and a new DVD reader needs to be installed.
The buttons on the DVD player are not responding
The DVD player is not responding when the buttons are pressed.
The buttons are stuck
If there is no audible click when the buttons are pressed down, then the mechanism that attaches the buttons to the circuit board may be malfunctioning. You will need to remove the button circuit board and then realign or replace it.
The button circuit board is broken
If the lights on the screen are not showing and the DVD player is not responding to the buttons, then there may be an issue with the button circuit board. If so you will need to replace the button circuit board.
The processing circuit board is broken
If installing a new button circuit board did not work, the processing board may have a problem. Replacing the processing board may solve the problem.
The DVD player is not turning on
The DVD player is off and cannot be turned on.
The power cord is faulty
If the DVD player will not turn on, then there may be a problem with the power cord. To install a new power chord you must remove the top cover of the DVD player, pinch the power cord’s clip at its base, and pull it out.
If replacing the power cord does not work but the remote still turns the device on, then the button circuit board may be broken. Installing a new button circuit board may correct the problem.
The power supply board is broken
If replacing the power cord does not solve the problem and the remote is unable to turn the device on, there may be a problem with the power supply board. Installing a new power supply board may solve the problem.
The audio or video is not connecting
The DVD player is reading the DVD/CD, but no sound can be heard and no video can be seen.
The processing board is broken
If the DVD is playing without sound or video, there may be an issue with the processing board. If so, installing a new processing board may solve the problem.
The DVD reader is broken
Even if the processing board is working the audio and visual might not work. If that is the case, there may be an issue with the DVD reader. First, check to see if the reader is blocked by anything. If the area above the reader seems clear, installing a new DVD reader may solve the problem.
The disk drawer is not fully ejecting
The disk drawer does not fully extend.
The DVD drive is broken
If the eject disc tray does not open fully, there may be a problem with the eject door. The plastic portion or inner mechanisms may be broken. Either way, Installing a new DVD drive may solve this problem.
Kaitlyn Reilly
54 Reputation
1 Guide authored
Cal Poly, Team 5-17, Forte Winter 2013 Member of Cal Poly, Team 5-17, Forte Winter 2013
CPSU-FORTE-W13S5G17
5 Members
72 Guides authored
6 Comments
Where in the world do I get the DVD Reader part from???
cubexyz - Reply Share
I can't get my my dvd out of the recorder Sony
Brian Moffat - Reply Share
I can't get my dvd out of my dvd recorder it is a Sony
Help - Sony Dvd player - DVPSR200P On/Off Standby Power Switch plastic sub-assembly is broken - need drawing to attempt repair, or replacement part - thank you
David Sekora - Reply Share
I have a sony DVP-SR200P IT WILL PLAY FOR A FEW MINUTES THEN SHUT OFF
Jeff Brooker - Reply Share
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 63
All Time: 14,109
