Sony DVP-SR200P Button Circuit Board Replacement
  1. Sony DVP-SR200P Button Circuit Board Replacement, Top Cover: step 1, image 1 of 2 Sony DVP-SR200P Button Circuit Board Replacement, Top Cover: step 1, image 2 of 2
    • Remove the five #1 Phillips screws (black, 3/16") attaching the cover to the DVD player.
    • One 3/16" screw on the right side of the DVD player.
    • One 3/16" screw on the left side of the DVD player (directly opposite of other screw).
    • Three 3/16" screws on the back of the DVD player.
    Ask FixBot
  2. Sony DVP-SR200P Button Circuit Board Replacement: step 2, image 1 of 2 Sony DVP-SR200P Button Circuit Board Replacement: step 2, image 2 of 2
    • Slide the cover away from the front of the DVD player until it is off.
    Ask FixBot
  3. Sony DVP-SR200P Button Circuit Board Replacement, Processing Board: step 3, image 1 of 1
    • Remove the blue tape from the processing board by gently pulling upward.
    Ask FixBot
  4. Sony DVP-SR200P Button Circuit Board Replacement: step 4, image 1 of 2 Sony DVP-SR200P Button Circuit Board Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Use the tweezers to remove the four sets of wires connected to the processing board. Start with the cord located in front of the row of three cords.
    • The wires may be difficult to remove. Wiggling them while lifting them up may help remove them.
    Ask FixBot
  5. Sony DVP-SR200P Button Circuit Board Replacement: step 5, image 1 of 1
    • Handle the processing board with care. It is fragile.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the two edge corners of the processing board.
    Ask FixBot
  6. Sony DVP-SR200P Button Circuit Board Replacement: step 6, image 1 of 1
    • Orient the DVD player so that you are facing the video and audio jacks.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the outside of the DVD player
    • The processing board is now free to be removed and replaced.
    Ask FixBot
  7. Sony DVP-SR200P Button Circuit Board Replacement, DVD Drive: step 7, image 1 of 1
    • Orient the DVD player so the front of the DVD player is opposite of you.
    • Remove the two #1 Phillips screws (silver, 3/16") that attach the DVD drive to the bottom of the DVD player.
    Ask FixBot
  8. Sony DVP-SR200P Button Circuit Board Replacement: step 8, image 1 of 1
    • Remove the DVD drive by pulling it backward and upward while ensuring that it is free of any braces.
    Ask FixBot
  9. Sony DVP-SR200P Button Circuit Board Replacement, Button Circuit Board: step 9, image 1 of 3 Sony DVP-SR200P Button Circuit Board Replacement, Button Circuit Board: step 9, image 2 of 3 Sony DVP-SR200P Button Circuit Board Replacement, Button Circuit Board: step 9, image 3 of 3
    • Orient the DVD player so the button circuit board is facing you.
    • Remove the four #1 Phillips screws (silver, 3/16") from the button circuit board.
    • Three 3/16" screws from the longer button circuit board.
    • One 3/16" screw from the smaller button circuit board.
    Ask FixBot
  10. Sony DVP-SR200P Button Circuit Board Replacement: step 10, image 1 of 3 Sony DVP-SR200P Button Circuit Board Replacement: step 10, image 2 of 3 Sony DVP-SR200P Button Circuit Board Replacement: step 10, image 3 of 3
    • Hold down the copper brace that is near the far right screw hole of the long circuit board.
    • Lift the longer button circuit board over the copper brace and out of its position.
    Ask FixBot
  11. Sony DVP-SR200P Button Circuit Board Replacement: step 11, image 1 of 3 Sony DVP-SR200P Button Circuit Board Replacement: step 11, image 2 of 3 Sony DVP-SR200P Button Circuit Board Replacement: step 11, image 3 of 3
    • Push back the black, plastic clip near the left center of the shorter button circuit board.
    • Pull the shorter button circuit board out of its position.
    Ask FixBot
  12. Sony DVP-SR200P Button Circuit Board Replacement: step 12, image 1 of 2 Sony DVP-SR200P Button Circuit Board Replacement: step 12, image 2 of 2
    • Wiggle the white cord connecting the two boards out from under the plastic pieces securing the cord.
    • Lift the button circuit board out of the DVD player.
    Ask FixBot
2 other people completed this guide.
Jeffrey Powell
157 Reputation
1 Guide authored
Cal Poly, Team 5-17, Forte Winter 2013 Member of Cal Poly, Team 5-17, Forte Winter 2013
CPSU-FORTE-W13S5G17
5 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 32
All Time: 2,818
