Sony DVP-SR200P DVD Reader Replacement
    1. Sony DVP-SR200P DVD Reader Replacement, Top Cover: step 1, image 1 of 2 Sony DVP-SR200P DVD Reader Replacement, Top Cover: step 1, image 2 of 2
      • Remove the five #1 Phillips screws (black, 3/16") attaching the cover to the DVD player.
      • One 3/16" screw on the right side of the DVD player.
      • One 3/16" screw on the left side of the DVD player (directly opposite of other screw).
      • Three 3/16" screws on the back of the DVD player.
      Ask FixBot
    2. Sony DVP-SR200P DVD Reader Replacement: step 2, image 1 of 2 Sony DVP-SR200P DVD Reader Replacement: step 2, image 2 of 2
      • Slide the cover away from the front of the DVD player until it is off.
      Ask FixBot
    1. Sony DVP-SR200P DVD Reader Replacement, Processing Board: step 3, image 1 of 1
      • Remove the blue tape from the processing board by gently pulling upward.
      Ask FixBot
    2. Sony DVP-SR200P DVD Reader Replacement: step 4, image 1 of 2 Sony DVP-SR200P DVD Reader Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Use the tweezers to remove the four sets of wires connected to the processing board. Start with the cord located in front of the row of three cords.
      • The wires may be difficult to remove. Wiggling them while lifting them up may help remove them.
      Ask FixBot
    3. Sony DVP-SR200P DVD Reader Replacement: step 5, image 1 of 1
      • Handle the processing board with care. It is fragile.
      • Unscrew the two #1 Phillips screws (silver, 3/16") located on the two edge corners of the processing board.
      Ask FixBot
    4. Sony DVP-SR200P DVD Reader Replacement: step 6, image 1 of 1
      • Orient the DVD player so that you are facing the video and audio jacks.
      • Unscrew the two #1 Phillips screws (silver, 3/16") located on the outside of the DVD player
      • The processing board is now free to be removed and replaced.
      Ask FixBot
    1. Sony DVP-SR200P DVD Reader Replacement, DVD Drive: step 7, image 1 of 1
      • Orient the DVD player so the front of the DVD player is opposite of you.
      • Remove the two #1 Phillips screws (silver, 3/16") that attach the DVD drive to the bottom of the DVD player.
      Ask FixBot
    2. Sony DVP-SR200P DVD Reader Replacement: step 8, image 1 of 1
      • Remove the DVD drive by pulling it backward and upward while ensuring that it is free of any braces.
      Ask FixBot
    1. Sony DVP-SR200P DVD Reader Replacement, DVD Reader: step 9, image 1 of 3 Sony DVP-SR200P DVD Reader Replacement, DVD Reader: step 9, image 2 of 3 Sony DVP-SR200P DVD Reader Replacement, DVD Reader: step 9, image 3 of 3
      • Flip the DVD drive upside down, to match the orientation of the first picture.
      • Carefully remove the white ribbon cable from the brace holding it in place by sliding it out towards you.
      • Next remove the brace from the DVD drive. Carefully wiggle and pull the brace upward as the white ribbon cable slides out through the brace.
      Ask FixBot
    2. Sony DVP-SR200P DVD Reader Replacement: step 10, image 1 of 1
      • Remove the four silver #1 Phillips 3/16''screws to free the DVD reader from the DVD drive.
      Ask FixBot
    3. Sony DVP-SR200P DVD Reader Replacement: step 11, image 1 of 1
      • Remove the DVD reader from the DVD drive by pulling it upwards off of the drive.
      • The DVD reader can now be replaced.
      Ask FixBot
3 other people completed this guide.
Jose Coronel
84 Reputation
1 Guide authored
Cal Poly, Team 5-17, Forte Winter 2013 Member of Cal Poly, Team 5-17, Forte Winter 2013
CPSU-FORTE-W13S5G17
5 Members
72 Guides authored
1 Guide Comment
Which part help to play games in dvd player
WWE Final Fighters - Reply Share
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 57
All Time: 5,632
