Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Tablet Not Charging
Nothing happens when you try plugging the tablet into a power source.
Charging-Cord is Broken
Make sure the charging-cord is not severed in any way, if so try using a new one.
Tablet Needs Restarting
See "How To Restart My Tablet".
Battery is Faulty
The battery in the tablet could be broken and it may need replacing.
Touchscreen Will Not Respond
Screen will start up, but interactions will not register.
Screen Needs Cleaning
Gently rub the screen with a cleaner, using a soft fabric or microfiber cloth.
Motherboard is Faulty
Attempt to restart the tablet, see “How To Restart My Tablet”. If this fails the motherboard may need replacing.
Screen is Broken
If none of the above fixes your issue then the screen may need replacing.
No Sound Playing
Sound associated with music or video will not work.
Sound is Muted
Go into settings on the tablet. Make sure the sound is not muted.
Attempt the restart the tablet, see "How To Restart My Tablet".
Speaker is Broken
If sound still isn’t coming from the speaker then it may need replacing.
Microphone Will Not Work
Sound on your recordings or video chat is not registering into the microphone.
Sound is Muted
Microphone Port is Dirty
Inspect the microphone port on the bottom of the tablet. Clean with a fine tool, use soft fabric if necessary.
Attempt to restart the tablet, see "How To Restart My Tablet".
Microphone is Broken
If sound still is not registering into the microphone it needs to be replaced.
Camera Will Not Work
Camera is not functioning properly or pictures come out blurry.
Lens is Dirty
Gently rub the lens with a soft fabric; use cleaner if necessary.
Camera is Broken
The pictures still appear blurry or do not come out at all; the camera lens needs to be replaced.
Wifi Will Not Work
Network signal or wifi connection is being spotty or not working at all.
Wifi Signal Cannot Be Found
Go into the settings on the tablet; make sure the wifi finder is turned on.
Network Connection Cannot Be Established
As this is most likely a network problem, be sure to check that the network you are trying to connect to is running properly.
Antenna is Broken
If none of the above fixes your issue then the antenna may need replacing.
You must first disconnect the tablet from the power source if necessary. Press and hold the power button, a pop-up menu of options will appear. Touch “Power off” and then “OK”. Pressing and holding the power button when the tablet is shut off will turn the tablet back on.
Elizabeth Wittliff
176 Reputation
1 Guide authored
Baylor, Team 6-5, Williams Fall 2015 Member of Baylor, Team 6-5, Williams Fall 2015
BU-WILLIAMS-F15S6G5
3 Members
48 Guides authored
2 Comments
The sim card and buttons don't work the sim card never did
Jeffrey Faas - Reply Share
I have the same issue I can't get the tablets power button or the volume buttons to work at all I've only had the thing for a few months and it was crazy expensive to buy
Ashleigh81016 - Reply Share
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 851
