Skytex Skypad Alpha 2 Antenna Replacement
  1. Skytex Skypad Alpha 2 Antenna Replacement, Back Cover: step 1, image 1 of 1
    • Power off the tablet.
    • Unplug the tablet from the power source if it is connected.
    Ask FixBot
  2. Skytex Skypad Alpha 2 Antenna Replacement: step 2, image 1 of 2 Skytex Skypad Alpha 2 Antenna Replacement: step 2, image 2 of 2
    • Remove the (4) 3.5mm screws using a phillips #000 screwdriver.
    Ask FixBot
  3. Skytex Skypad Alpha 2 Antenna Replacement: step 3, image 1 of 1
    • Use the plastic opening tool to work your way around the tablet, releasing the back case from the tabs.
    Ask FixBot
  4. Skytex Skypad Alpha 2 Antenna Replacement: step 4, image 1 of 1
    • Release the back case from the rest of the tablet with your hand.
    • Do not pry the case too hard; doing so can damage the tablet.
    Ask FixBot
  5. Skytex Skypad Alpha 2 Antenna Replacement, Antenna: step 5, image 1 of 1
    • Remove the metallic electrical tape, just enough, to allow the antenna to hang freely.
    • Remove all black and yellow tape, if necessary, on the motherboard.
    Ask FixBot
  6. Skytex Skypad Alpha 2 Antenna Replacement: step 6, image 1 of 1
    • Remove the soldered connections to separate the antenna wire from the motherboard.
    • The antenna wire will be connected to the motherboard with 2 connections, so be sure to remove both with the soldering iron.
    • Follow the link below for further soldering information: How To Solder and Desolder Connections.
    • Soldering irons require a large amount of heat; use caution when performing this step. Excessive heat can damage parts of your device; do not leave the soldering iron on connections for extended periods of time.
    Ask FixBot
  7. Skytex Skypad Alpha 2 Antenna Replacement: step 7, image 1 of 1
    Tool used on this step:
    Buy
    • Remove the antenna from the tablet using a pair of tweezers.
    • The antenna is actually fastened inside the back case of the tablet, pull gently to free it from the adhesive.
    Ask FixBot
Rebecca Ramirez
481 Reputation
3 Guides authored
Baylor, Team 6-5, Williams Fall 2015 Member of Baylor, Team 6-5, Williams Fall 2015
BU-WILLIAMS-F15S6G5
3 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 24
All Time: 279
