Skytex Skypad Alpha 2 Battery Replacement
    1. Skytex Skypad Alpha 2 Battery Replacement, Back Cover: step 1, image 1 of 1
      • Power off the tablet.
      • Unplug the tablet from the power source if it is connected.
      Ask FixBot
    2. Skytex Skypad Alpha 2 Battery Replacement: step 2, image 1 of 2 Skytex Skypad Alpha 2 Battery Replacement: step 2, image 2 of 2
      • Remove the (4) 3.5mm screws using a phillips #000 screwdriver.
      Ask FixBot
    3. Skytex Skypad Alpha 2 Battery Replacement: step 3, image 1 of 1
      • Use the plastic opening tool to work your way around the tablet, releasing the back case from the tabs.
      Ask FixBot
    4. Skytex Skypad Alpha 2 Battery Replacement: step 4, image 1 of 1
      • Release the back case from the rest of the tablet with your hand.
      • Do not pry the case too hard; doing so can damage the tablet.
      Ask FixBot
    1. Skytex Skypad Alpha 2 Battery Replacement, Battery: step 5, image 1 of 1
      • Remove soldered connections to separate the battery wires from the motherboard.
      • Remove all black and yellow tape, if necessary, on motherboard.
      • Following the red and black wires, that come out of the battery, to their respective connections on the motherboard will indicate where to solder.
      • Follow link for further soldering information: How to Solder and Desolder Connections
      Ask FixBot
    2. Skytex Skypad Alpha 2 Battery Replacement: step 6, image 1 of 1
      • Use the plastic opening tool to remove battery from tablet.
      • Be sure to remove the battery carefully to avoid damage. Damage of battery can release harmful chemicals and may cause a fire.
      Ask FixBot
Rebecca Ramirez
481 Reputation
3 Guides authored
Baylor, Team 6-5, Williams Fall 2015 Member of Baylor, Team 6-5, Williams Fall 2015
BU-WILLIAMS-F15S6G5
3 Members
48 Guides authored
1 Guide Comment
Excellent Guide
Problem is where to obtain the Replacement battery ???
J P SULLIVAN - Reply Share
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 104
All Time: 1,252
