Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
No Signal or Acquiring Signal
Device display shows "No Signal" or "Acquiring Signal"
The device is off air
If your device displays that it is off air, first make sure the device is connected to the docking station properly. If the device is properly connected either the selected channel is not currently available or data is being received from the satellite and information will be available in a moment.
"No Antenna" or "Antenna Not Detected"
"No Antenna" or "Antenna Not Detected" is displayed on device and It will not connect to a channel
Faulty Antenna
Check to ensure the docking station is securely connected to the device. If the connection is secure check if antenna is connected to the docking station. Once you have checked that, turn the device off and back on to reset the device.
If antenna and docking stations are properly connected, check if antenna is obscured, or damaged in any areas, either along the cord or the receptor itself.
If the antenna is bent or broken it may be necessary to replace the antenna.
Faulty Antenna connection to the Device
If the device is well connected to the docking station, and the antenna is in working condition it may be necessary to either replace the docking station or mother board.
Click here to change docking station components.
Click here for motherboard replacement.
Device not powering on
Device will not turn on when the power button is pressed
Faulty power cable or connection
Ensure that the power cable is connected to the docking station properly.
Check to see if the power cable is broken or bent in any areas and check that the light on the power adapter is on. If the power cable is broken, replace the cable.
If the connection and the cable are working it may be necessary to change out the docking station components.
Click here to change out docking station components.
Motherboard is broken
If the cable and docking station are in working condition it may be necessary to change out the mother board .
Improper connection to the docking station
The device has damage that will not allow it to connect the the docking station
Casing is Damaged
The device may be obstructed from a proper connection due to a bent or broken case at the point of connection.
Click here for case replacement.
Device is unresponsive
There is no response when pressing a button / all of the buttons
Buttons do not work
If buttons do not appear to have physical damage, and will not depress when clicked it may be necessary to dust the buttons and clean with rubbing alcohol and a q-tip.
If buttons are physically damaged they may not work properly at this point it it necessary to replace the devices buttons.
Click here for button replacement.
If the buttons are not working and appear to be in proper condition the device may not be receiving proper instructions, due to a malfunction within the motherboard.
Click here for motherboard repair.
Display is not working properly
The display is cracked, and/or the device is responsive but the display is failing to show proper items and is worn
If the device appears to have a distorted or cracked screen it is necessary to replace the screen so it does not get worse and become a hazard.
Click here for screen replacement.
If the front casing of the device is cracked in a manner that hinders viewing of the devices screen, it is necessary to replace the front panel/case of the device.
The display is worn
If the buttons are responsive but the display picture is faded, or it has a lasting image burned onto it (a ghost image), then the LED's in the screen might be burnt out. If this happens it is necessary to replace the screen.
Author
with
Kailash Permaul
51 Reputation
0 Guides authored
USF Tampa, Team S7-G2, Passmore Spring 2018 Member of USF Tampa, Team S7-G2, Passmore Spring 2018
USFT-PASSMORE-S18S7G2
4 Members
60 Guides authored
2 Comments
After five minutes of playing, it starts cutting out intermittently
Libby Bearss - Reply Share
I have 2 docks in my workshop' They have been working fine. Today when I turned on the docks they powered up fine but the serius cartridges would not power on in either one. I put the cartridges in another device and they worked fine. They only thing I did to both of them is put cheap batteries in the docks because thats all I could find because of the hurricane. It is strange they both went at the same time....any ideas? Thanks Jack
flyboy - Reply Share
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 31
All Time: 9,114
