SiriusXM Onyx Plus Motherboard Replacement
    1. SiriusXM Onyx Plus Motherboard Replacement, Case: step 1, image 1 of 1
      • Wedge a plastic opening tool in between the case.
      Ask FixBot
    2. SiriusXM Onyx Plus Motherboard Replacement: step 2, image 1 of 3 SiriusXM Onyx Plus Motherboard Replacement: step 2, image 2 of 3 SiriusXM Onyx Plus Motherboard Replacement: step 2, image 3 of 3
      • Starting with the bottom left corner, press down on the plastic opening tool to unhook the latches on the inside of the device.
      • You have to start with the bottom left and right corners, and then flip the device to over and do the top of the device.
      Ask FixBot
    3. SiriusXM Onyx Plus Motherboard Replacement: step 3, image 1 of 1
      • Once unclipped, separate the back casing from the device.
      Ask FixBot
    1. SiriusXM Onyx Plus Motherboard Replacement, Motherboard: step 4, image 1 of 2 SiriusXM Onyx Plus Motherboard Replacement, Motherboard: step 4, image 2 of 2
      • Remove the three 5.4mm JIS #00 screws from the motherboard.
      Ask FixBot
    2. SiriusXM Onyx Plus Motherboard Replacement: step 5, image 1 of 1
      • Unlatch the two clips located at the top of the device that hold the motherboard in place.
      Ask FixBot
    3. SiriusXM Onyx Plus Motherboard Replacement: step 6, image 1 of 1
      • Lift the motherboard up from the bottom.
      Ask FixBot
    4. SiriusXM Onyx Plus Motherboard Replacement: step 7, image 1 of 1
      • Lift the screen up, so you can see where it is attached to the motherboard.
      Ask FixBot
    5. SiriusXM Onyx Plus Motherboard Replacement: step 8, image 1 of 1
      • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
      Ask FixBot
    6. SiriusXM Onyx Plus Motherboard Replacement: step 9, image 1 of 1
      • Carefully pull the ribbon out from the ZIF connector.
      Ask FixBot
Angel Rivera
532 Reputation
5 Guides authored
USF Tampa, Team S7-G2, Passmore Spring 2018 Member of USF Tampa, Team S7-G2, Passmore Spring 2018
USFT-PASSMORE-S18S7G2
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 35
All Time: 2,290
