Up to 20% off select tools
SiriusXM Onyx Plus Buttons Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
12
Past 30 Days:
60
All Time:
646
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 4 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Buttons might tear and get worn out so it is important to replace the buttons.
    1. SiriusXM Onyx Plus Buttons Replacement, Case: step 1, image 1 of 1
      • Wedge a plastic opening tool in between the case.
      Ask FixBot
    2. SiriusXM Onyx Plus Buttons Replacement: step 2, image 1 of 3 SiriusXM Onyx Plus Buttons Replacement: step 2, image 2 of 3 SiriusXM Onyx Plus Buttons Replacement: step 2, image 3 of 3
      • Starting with the bottom left corner, press down on the plastic opening tool to unhook the latches on the inside of the device.
      • You have to start with the bottom left and right corners, and then flip the device to over and do the top of the device.
      Ask FixBot
    3. SiriusXM Onyx Plus Buttons Replacement: step 3, image 1 of 1
      • Once unclipped, separate the back casing from the device.
      Ask FixBot
    1. SiriusXM Onyx Plus Buttons Replacement, Buttons: step 4, image 1 of 2 SiriusXM Onyx Plus Buttons Replacement, Buttons: step 4, image 2 of 2
      • Remove the three 5mm JIS #00 screws from the motherboard.
      Ask FixBot
    2. SiriusXM Onyx Plus Buttons Replacement: step 5, image 1 of 1
      • Unlatch the two clips that hold the motherboard in place.
      Ask FixBot
    3. SiriusXM Onyx Plus Buttons Replacement: step 6, image 1 of 1
      • Lift the motherboard up and out of the frame.
      Ask FixBot
    4. SiriusXM Onyx Plus Buttons Replacement: step 7, image 1 of 2 SiriusXM Onyx Plus Buttons Replacement: step 7, image 2 of 2
      • Holding the front casing in your hand, push the button panels out of the casing.
      • There are two buttons panels: Navigation panel and the Channel Number panel
      Ask FixBot
Author
with
Angel Rivera
532 Reputation
5 Guides authored
USF Tampa, Team S7-G2, Passmore Spring 2018 Member of USF Tampa, Team S7-G2, Passmore Spring 2018
USFT-PASSMORE-S18S7G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 60
All Time: 646
