Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Vacuum won't turn on
When the switch is turned on, I can’t hear the motor.
Plugged into a bad outlet
Before we assume there is a problem with your vacuum, you should make sure the outlet you are plugging into is functioning properly. First make sure any light switches that could be controlling the outlet are flipped into the "on" position. Next, plug in a different appliance; for example, a light or TV. Also make sure the test appliance is turned on. If the appliance turns on then the outlet is working properly. If not, check any breakers or call your electrician.
Defective motor
Check to make sure vacuum is plugged in and you flip the switch to the on position. If so, the motor could be malfunctioning. In order to fix this problem refer to the repair guide for a malfunctioning motor.
Defective switch
Check to make sure vacuum is plugged in and power switch is flipped to on position. If so, the switch could have poor connections. To fix this issue refer to the repair guide for replacing the switch.
Short in power cable
Another cause for loss of power in the vacuum could be a short in the power cable. Shorts in wires can become an electrical hazard. One way to make sure there is a short is to curl the wire at two inch intervals to see if it affects the power going to the vacuum. If there is a short refer to the repair guide for replacing the power cord.
Dust coming out of hose
When I'm vacuuming , dust comes out of the vacuum's hose.
No filter installed
Unplug and turn off the shop vac. Remove the black top off of shop vac. Make sure the black foam filter is in place and a clean filter bag is in place. The filter bag should only be used for dirt and dry debris.
Damaged filter
Turn off and unplug the shop vac. Remove black top off the shop vac. If the black foam sleeve or the filter bag are damaged remove them and replace them with new filters.
Clogged filter
A clogged filter can cause over heating in the motor. Make sure the shop vac is unplugged and turned off. Remove the black top of the shop vac. Then, remove the clogged filter. Either replace the filter or clean out the filter. You can also choose a more efficient filter if you have frequent clogging.
Broken filter housing
A broken filter housing could cause problems with retaining the dust that has been vacuumed up. Open the vacuum to make sure the filters are in place and check the filter housing inside the vacuum. If you see that it is broken refer to the repair guide for repairing the housing.
Loss of suction
When I'm vacuuming, my vacuum doesn't suck dust as hard as it used to.
Loose hose
One common reason for poor suction is a improperly connected hose. Look at the connection between the hose and the vacuum and push the hose all the way in to insure the hose is fully connected.
Filter clogged
If the sweeper is working but you can feel the suction is very weak, you could have a clogged filter. Open up the vacuum and look at the filter foam sleeve, If it looks really dirty or covered in a lot of dust, then it may be clogged and restricting airflow through the sweeper. Remove the filter and clean it or replace it with a new one.
Full tank
If you have been losing suction and sweeping up a huge mess or if it has been a long time since you last dumped the sweeper, the sweeper tank could be full. A full tank can affect airflow in the sweeper. To fix this issue you should first issue open up the sweeper. For dry messes remove the filter bag, throw it away, and replace it with a new one. For wet messes, dump the main sweeper tank and make sure it is clean.
Hole in hose
With the vacuum turned on cover the end of the hose. You can have a friend or yourself run a hand down the tube part of the hose. If you can feel air still trying to be sucked in, then there is a hole in the hose. You will have to purchase a new hose.
Sara York
109 Reputation
0 Guides authored
IUPUI, Team 1-2, Baechle Spring 2016 Member of IUPUI, Team 1-2, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G2
5 Members
60 Guides authored
14 Comments
I have a 12 gallon vac. Why does air blow out the hole discharge at the same time when the hose is plugged into the vacuum end? I just installed a new filter.
Yunko - Reply Share
Did you ever solve this? Mine is doing the same thing. I took it apart, cleaned out all loose debris and installed all new filters and it hadn’t helped.
Deni Ackeridge - Reply Share
Hey, I was wondering if u ever figured out if it was Normal or an Issue that your Shop Vac was blowing air outta the Rear Blower Port, an suctioning air from the Front Blower Port at the Same Time.
I ask cause I have the Exact thing happening to me.
I turned the vacuum on to vacuum up drywall dust an right from the very beginning I had Suction from the Front Port an Blowing coming outta the Rear Port at the same time.
I'd love to know if you figured out what's going on.
Thank You
Amanda MacIn - Reply Share
I have this problem also wirh my Craftsman shop vav … new vacuum, first time use, new filter, everything in excellent condition and properly seated filter. Need an answer. Vacuum works anyhow and no dust is blowing out, and it appears designed to do both at the same time…disturbing. Turning the blower off or on requires some type of blower switch, and instructions say to just plug in the hose on the blower hole to turn it on, but there is no sign of any switch, magnet, or other anywhere around the blower opening. I think it is built to be always on.
Karyl St Pierre - Reply Share
Air sucks in the vacuum port, swirls through the canister, then travels through the filter and over the motor (to cool it) and is exhausted out the blower port.
The air flows this way regardless of the port you plugged the hose into.
All vacuums exhaust air but some shop vacs take advantage of this to use as a blower option.
It’s not a bug, it’s a feature. =)
xsie - Reply Share
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 43
All Time: 35,621
