Shop-Vac MC150A Power Switch Replacement
    1. Shop-Vac MC150A Power Switch Replacement, Unlatch the power unit assembly: step 1, image 1 of 1
      • Before you begin, make sure to switch off the device and unplug it from the outlet.
      • Unlatch the two side clips securing the power unit assembly to the tank.
      • Remove the power unit assembly from the tank assembly.
      Ask FixBot
    2. Shop-Vac MC150A Power Switch Replacement, Remove the top cover: step 2, image 1 of 2 Shop-Vac MC150A Power Switch Replacement, Remove the top cover: step 2, image 2 of 2
      • Use a 3.5 mm hex key to remove the three screws securing the top cover.
      • Remove the top cover.
      Ask FixBot
    3. Shop-Vac MC150A Power Switch Replacement: step 3, image 1 of 1
      • Use a 3.5 mm hex key to remove the four screws securing the power unit assembly.
      Ask FixBot
    4. Shop-Vac MC150A Power Switch Replacement: step 4, image 1 of 1
      • Separate the power unit assembly from the cover.
      Ask FixBot
    1. Shop-Vac MC150A Power Switch Replacement, Disconnect the switch: step 5, image 1 of 3 Shop-Vac MC150A Power Switch Replacement, Disconnect the switch: step 5, image 2 of 3 Shop-Vac MC150A Power Switch Replacement, Disconnect the switch: step 5, image 3 of 3
      • Pull out and disconnect the four spade connectors from the switch module.
      • During reassembly, use the last image as a reference for how to connect the wires.
      Ask FixBot
    2. Shop-Vac MC150A Power Switch Replacement: step 6, image 1 of 1
      • Use a spudger to pry up and remove the red switch from the housing.
      Ask FixBot
6 other people completed this guide.
Ngunlian
756 Reputation
5 Guides authored
IUPUI, Team 1-2, Baechle Spring 2016 Member of IUPUI, Team 1-2, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G2
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 102
All Time: 18,646
