Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Vacuum Turned on but Not Picking Anything Up
After many attempts of trying to vacuum up the same piece of debris, the suction is still too weak.
Faulty Brush Head
If the vacuum’s power is on, but fails to pick up dirt, the issue may be a stalled revolving brush head. The brush head could be broken or otherwise incapable of operating. For brush head replacement, click here
Clogged Lift away vacuum motor
If vacuum components are clear and appear to be working properly, the vacuum motor may be failing. This is the central motor in the heart of the vacuum that provides the suction.
Vacuum has Foul Odor When Turned On
Smell coming from vacuum is foul and getting stronger.
Full Dust Cup
If the dust cup is full, empty and clean it. If the smell remains, remove filter cup and wash foam pads. Additionally, the dust cup may need to be replaced, for proper replacement,click here.
Burnt Motor
If there is a burning smell, the motor may be failing. Consider a motor replacement. For replacement guide, click here.
Vacuum Not Turning On
Vacuum is switched on, but nothing is happening.
Poor Outlets/connections
Make sure vacuum is completely plugged into outlet. Check if outlet is working. If not, try a separate outlet. If unsuccessful, could be a wiring issue.
Hose Blockage
There may be blockages in the hose. The vacuum is equipped with a safety feature that prevents the vacuum from powering on in response to blockage. Check to see if hose is clear. To detach hose, click here.
Vacuum Difficult to Push
Vacuum will hardly move.
Stiff Wheels
If vacuum is difficult to push, something may be caught in the wheel. Inspect wheel and clean out debris. If this does not resolve the issue, consider replacing the wheel.
Jammed Brush Head
There may be potential blockages formed from rugs or other forms of lengthy material. This material can wind around and prohibit the brush head from rotating, limiting the ability to move the vacuum. For Brush Head inspection, click here.
Vacuum Makes Odd Sounds
Once the vacuum is turned on, it is making a funny noise.
Debris in hose
If vacuum is making sounds, debris may be caught in the hose. To remove debris, take off the hose and clear the hose. To detach hose, click here.
Full Bin
The bin may also be full. Thoroughly clean the bin out and continue use. If any problems arise refer to solutions above for troubleshooting.
Kyle Detwiler
34 Reputation
0 Guides authored
Cal Poly, Team S4-G6, Livingston Fall 2017 Member of Cal Poly, Team S4-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G6
3 Members
70 Guides authored
4 Comments
Vacuum turns on nothing is happening
pamschmidt - Reply Share
vacumn on but brush motor does not drive brush. pwer to head ok. What can be wrong?
Clive Kingscote - Reply Share
Extender wand wont click back into place
Linda Atkinson - Reply Share
Extender wand wont clickback into place
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 24
All Time: 12,374
