Shark Navigator Lightweight Upright Hose Replacement
    1. Shark Navigator Lightweight Upright Hose Replacement, Hose: step 1, image 1 of 3 Shark Navigator Lightweight Upright Hose Replacement, Hose: step 1, image 2 of 3 Shark Navigator Lightweight Upright Hose Replacement, Hose: step 1, image 3 of 3
      • Locate the upper connection of the hose found directly below the base of the handle. Push in the the tab on the outside of the tube with your thumb.
      • Pull down on the tube while maintaining pressure on the tab.
      • Separate the upper connection of the tube from the housing, releasing the hose.
      Ask FixBot
    2. Shark Navigator Lightweight Upright Hose Replacement: step 2, image 1 of 2 Shark Navigator Lightweight Upright Hose Replacement: step 2, image 2 of 2
      • Locate the lower attachment of the hose found in the bottom left corner.
      • Pull the hose down towards the floor, releasing the hose from the hose guide.
      Ask FixBot
    3. Shark Navigator Lightweight Upright Hose Replacement: step 3, image 1 of 3 Shark Navigator Lightweight Upright Hose Replacement: step 3, image 2 of 3 Shark Navigator Lightweight Upright Hose Replacement: step 3, image 3 of 3
      • Pull up on the hose pipe located on the right side of the vacuum firmly.
      • Lift the hose pipe upwards and all the way through the plastic guide ring.
      Ask FixBot
Kahye Yu
489 Reputation
2 Guides authored
Cal Poly, Team S4-G6, Livingston Fall 2017 Member of Cal Poly, Team S4-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G6
3 Members
70 Guides authored
3 Guide Comments
Where can I find a replacement hose?
Vance Payne - Reply Share
How to replace the bottom pick up hose.
rgg20319 - Reply Share
How to fix the bottom hose?
Past 24 Hours: 4
Past 7 Days: 50
Past 30 Days: 114
All Time: 5,063
