Shark Navigator Lightweight Upright Motor Replacement
    1. Shark Navigator Lightweight Upright Motor Replacement, Head Shell: step 1, image 1 of 2 Shark Navigator Lightweight Upright Motor Replacement, Head Shell: step 1, image 2 of 2
      • Detach the hose connected on the bottom of the vacuum by pulling it out of the casing.
      Ask FixBot
    2. Shark Navigator Lightweight Upright Motor Replacement: step 2, image 1 of 2 Shark Navigator Lightweight Upright Motor Replacement: step 2, image 2 of 2
      • Lay the vacuum on its side.
      • Press in the black, rubberish button located on the back of the vacuum to detach the vacuum head from the body.
      Ask FixBot
    3. Shark Navigator Lightweight Upright Motor Replacement: step 3, image 1 of 1
      • Flip over the vacuum head so the brush head is facing up.
      Ask FixBot
    4. Shark Navigator Lightweight Upright Motor Replacement: step 4, image 1 of 3 Shark Navigator Lightweight Upright Motor Replacement: step 4, image 2 of 3 Shark Navigator Lightweight Upright Motor Replacement: step 4, image 3 of 3
      • Remove the small front wheels with a metal spudger by inserting the metal spudger in front of the wheel and slowly prying up. This will free the wheel and reveal the screw beneath it.
      • Repeat this for the other wheel.
      Ask FixBot
    5. Shark Navigator Lightweight Upright Motor Replacement: step 5, image 1 of 2 Shark Navigator Lightweight Upright Motor Replacement: step 5, image 2 of 2
      • Remove the two 18mm screws with a JIS 1 screwdriver.
      Ask FixBot
    6. Shark Navigator Lightweight Upright Motor Replacement: step 6, image 1 of 2 Shark Navigator Lightweight Upright Motor Replacement: step 6, image 2 of 2
      • Remove the four 18mm screws located on the top corners and the bottom/middle of the vacuum head using a JIS 1 screwdriver.
      Ask FixBot
    7. Shark Navigator Lightweight Upright Motor Replacement: step 7, image 1 of 2 Shark Navigator Lightweight Upright Motor Replacement: step 7, image 2 of 2
      • Remove the two 18mm screws located on the inside of the large wheels using a JIS 1 screwdriver.
      Ask FixBot
    8. Shark Navigator Lightweight Upright Motor Replacement: step 8, image 1 of 3 Shark Navigator Lightweight Upright Motor Replacement: step 8, image 2 of 3 Shark Navigator Lightweight Upright Motor Replacement: step 8, image 3 of 3
      • Remove the plastic cover by prying the plastic cover up using a plastic opening tool.
      • Prying in multiple locations may be necessary to create separation.
      Ask FixBot
    1. Shark Navigator Lightweight Upright Motor Replacement, Motor: step 9, image 1 of 1
      • Locate the motor on the top right corner of the vacuum head shell.
      Ask FixBot
    2. Shark Navigator Lightweight Upright Motor Replacement: step 10, image 1 of 3 Shark Navigator Lightweight Upright Motor Replacement: step 10, image 2 of 3 Shark Navigator Lightweight Upright Motor Replacement: step 10, image 3 of 3
      • Remove the belt from the motor gear by sliding the belt to the right.
      Ask FixBot
    3. Shark Navigator Lightweight Upright Motor Replacement: step 11, image 1 of 3 Shark Navigator Lightweight Upright Motor Replacement: step 11, image 2 of 3 Shark Navigator Lightweight Upright Motor Replacement: step 11, image 3 of 3
      • Remove the white metal wire connector from the motor.
      • The white cable is positive.
      Ask FixBot
    4. Shark Navigator Lightweight Upright Motor Replacement: step 12, image 1 of 2 Shark Navigator Lightweight Upright Motor Replacement: step 12, image 2 of 2
      • Remove the black metal wire connector from the motor.
      • The black cable is negative.
      Ask FixBot
4 other people completed this guide.
Suzie
545 Reputation
4 Guides authored
Cal Poly, Team S4-G6, Livingston Fall 2017 Member of Cal Poly, Team S4-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G6
3 Members
70 Guides authored
2 Guide Comments
Where does one buy the replacement motor?
Michael De La Rosa - Reply Share
Where can I get spares??
ck
Clive Kingscote - Reply Share
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 41
All Time: 10,614
