Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Shark IQ AV993 Won't Turn on
Flicking on switch doesn't turn on device
Clogged Filters
Ensure there is a not a lot of dirt or hair clogged in your filters because it will cause the vacuum to lose suction and not turn on. Check your instruction booklet to see if the filter is washable. Remove the filter from the vacuum and remove any dirt off the top. Run the filter under cold water until it runs clear, and the filter is clean. You can wring the filter out; just make sure not to squeeze too hard and break the filter. Wait until it is completely dry and insert the filter back into the robot.
Faulty Power Plug
Make sure the vacuum's dock is firmly plugged into the wall outlet. Ensure the plug is not loose in the outlet and cannot wiggle around. Unplug the cord and plug it back in. Test your power socket. Plug in another device like your phone and see if it charges. If there are no issues here, there may be a faulty outlet in your home.
Battery Replacement
If both conditions have been met and your Shark IQ AV993 still won't turn on, there is most likely an issue with the battery and it must be replaced. See the step-by-step replacement guide: Replacing the battery in the Shark IQ AV993
Bumper out of Position
The bumper is dislodged and out of zero-degree, horizontal position
Bumper misaligned
Tap the front bumper to find which side is dislodged. Without taking the bot apart, see if there is some give in the bumper position, and you can move it back into its natural position. Apply some pressure to either the top of the bumper or the front to see if it will pop back into position.
Damaged Metal Bracket
In taking the front bumper off, there is a metal bracket that may become bent out of place, affecting the position and effectiveness of the bumper. This thin metal bracket can be easily torqued back into its original position, giving the bumper its bumpiness and position back.
Bumper Replacement
If the bumper is cracked from a severe fall or other circumstances, resulting in the bumper not returning to its effective position, a new bumper and/or metal bracket supporting the bumper will need to be replaced.
Debris left Behind Vacuum
Vacuum not cleaning properly causing the vacuum to spin in one spot
Clogged Roller Brush
If there is debris or materials caught up in the roller brush, the debris can get between the motor and the housing, making the wheel resistant to turning. Taking out the wheel from the housing, debris can be removed and function should return to normal. Additionally, cleaning out any material in the brushes themselves should help with the function of the vacuum.
Roller Brush Replacement
If debris is still being left behind, the brush itself might have worn down to a point where they are ineffective. Replacing the roller brush will solve this problem, as the new brushes should pick up materials the vacuum runs over.
Front Caster Wheel Not Spinning
Front 360 degree caster wheel resistant to spinning
Clogged Axel and Wheel
Inspecting the front wheel, if there is debris all around it, this might cause it to not spin properly.
To clean, pull the wheel directly from the housing, where you can clean the axel. Additionally, wipe out the space which holds the wheel, as there are sensors there that can be dirty, causing improper function. With the wheel and housing removed, remove the wheel from the housing and clean that individually, which can then be easily popped back into place.
Front Caster Wheel Replacement
If this doesn’t result in proper function, replacing the caster wheel itself may be necessary
Main Rear Wheels Not Spinning
Main wheels resistant to spinning in proper fashion.
Clogged wheels/motor
With increased usage time, the wheels can become clogged with hair/debris and cause an error code or will noticeably not work correctly/efficiently. Removing the wheels and taking them apart, this debris causing the issues can be removed, potentially creating better function.
Main Wheel Replacement
Upon taking the wheel apart, the plastic housing of the wheel may crack and break. If the plastic housing is broken in any way, it will only break further over time, causing reduced function. This would result in the wheel assembly needing a replacement for the whole assembly.
Sensors not working (leaving boundaries)
Sensors aren't working properly or not working at all.
Sensors blocked
First thing to do is to check if the sensors are clean, if not, then gently dust off the cliff sensors with a clean, dry cloth.
Faulty Connection
If cleaning the sensors didn't help fix the problem, then next thing to do is make sure all the sensors are plugged in and connected properly. Do so by pushing and tapping on each sensor making sure nothing is loose.
Motherboard Replacement
If both steps didn't resolve the issue, then the motherboard may need to be replaced. See step-by-step guide: Replacing the motherboard in the Shark IQ AV993
Author
with
Kyle Rhines
600 Reputation
4 Guides authored
UMass Dartmouth, Team 3-3, Botvin Fall 2022 Member of UMass Dartmouth, Team 3-3, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G3
3 Members
72 Guides authored
3 Comments
Hi, I used to remove the main brush and clean but I haven't been able to for a while now any idea how to fix that?
Nancy - Reply Share
@nancy77259 We have a guide on our page how to remove the brush. When you do end up removing it use a pair of scissors to cut off all picked up hair, tweezer may be a helpful tool as well.
Cole Travers - Reply Share
Hey there. I should follow the motherboard guide to get access to the inside of the cliff sensors, yeah? I'm getting faulty "the device is on or near a ledge, please move". The sensors are cloudy from what I'm guessing is overzealous cleaning
Joe the Bustamante guy - Reply Share
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 33
All Time: 1,253
