Shark IQ AV993 Battery Replacement
    1. Shark IQ AV993 Battery Replacement, Battery: step 1, image 1 of 1
      • Unscrew the two 14 mm screws on the battery panel using a Phillips #1 screwdriver.
      Ask FixBot
    2. Shark IQ AV993 Battery Replacement: step 2, image 1 of 1
      • Gently pull the white tabs on the battery straight upward.
      • There is a clip inserted into a plastic housing via wiring. Disconnect the battery by pressing in the clip.
      • Don't pull up on the battery too hard as a wire connects to the robot. Don't want to damage the wire here.
      • Remove the battery from the device.
      Ask FixBot
3 other people completed this guide.
Kyle Rhines
600 Reputation
4 Guides authored
UMass Dartmouth, Team 3-3, Botvin Fall 2022 Member of UMass Dartmouth, Team 3-3, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G3
3 Members
72 Guides authored
1 Guide Comment
This guide is also applicable to the Shark Matrix UR2360S. Thanks!
pyt - Reply Share
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 23
All Time: 760
