Shark IQ AV993 Bumper Replacement
    1. Shark IQ AV993 Bumper Replacement, Battery: step 1, image 1 of 1
      • Unscrew the two 14 mm screws on the battery panel using a Phillips #1 screwdriver.
      Ask FixBot
    2. Shark IQ AV993 Bumper Replacement: step 2, image 1 of 1
      • Gently pull the white tabs on the battery straight upward.
      • There is a clip inserted into a plastic housing via wiring. Disconnect the battery by pressing in the clip.
      • Don't pull up on the battery too hard as a wire connects to the robot. Don't want to damage the wire here.
      • Remove the battery from the device.
      Ask FixBot
    1. Shark IQ AV993 Bumper Replacement, Bumper: step 3, image 1 of 2 Shark IQ AV993 Bumper Replacement, Bumper: step 3, image 2 of 2
      • Remove the five 10 mm screws from the bottom of the device using a T15 Torx screwdriver.
      Ask FixBot
    2. Shark IQ AV993 Bumper Replacement: step 4, image 1 of 1
      • Pry both ends of the black piece to snap it out of place.
      Ask FixBot
    3. Shark IQ AV993 Bumper Replacement: step 5, image 1 of 1
      • Use both hands to lift the device.
      • The front bumper that is seated on the device will fall off.
      • This is completely normal, as the screws and the bottom holder are the only things holding the bumper in place.
      Ask FixBot
Kyle Rhines
600 Reputation
4 Guides authored
UMass Dartmouth, Team 3-3, Botvin Fall 2022 Member of UMass Dartmouth, Team 3-3, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G3
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 39
All Time: 1,645
