The Samsung SPH-A760 was the first generation of push to talk for Sprint. Unfortunately, it wasn't heavily advertised and therefore wasn't used by a large audience. This lead to problems with newer versions because the older versions were not tested thoroughly in the field.
Screen Isn't Working
If the Samsung SPH-A760 main screen is not working, it is either due to physical damage or a bad circuit connection.
Physical Damage
The Samsung SPH-A760 is a flip-phone, while this configuration normally protects the screen from damage when not in use, there is a chance that large amounts of pressure will cause damage to the screen. Disassembling Samsung SPH-A760 Screen
Bad Connection
Similar to physical damage to the exterior of the phone, the interior circuit connections that connect the screen to the logic board may be damaged as well. Disassembling Samsung SPH-A760 Screen
No Sound
Speakers are faulty
If you suspect that your speakers are not working then it is advised to replace them. A simple replacement of speakers will consume less time and get your phone back to function normally. Samsung SPH-A760 Speakers Replacement
Speakers aren't connected properly
This can easily be fixed by reconnecting the wires properly. If that fails, then you can safely assume that one of the wire is internally malfunctioning and creating an open circuit. Use a different set of wires, solder it to the speakers and to the screen, and then see if the phone works. Samsung SPH-A760 Speakers Replacement
Microphone
Bad Connection
If the connection is faulty then the first thing to do is to re-establish it. Connection problems can usually be solved by replacing or fixing the cables. This process will take from 5 to 30 minutes depending on which wires are not working. Samsung SPH-A760 Motherboard Replacement
Faulty microphone
If you suspect that your microphone is not working then it advised to replace the microphone or replace the logic board all together as the microphone is soldered on the logic board. Fixing the microphone is an option, but the components are so small, it would require great concentration and patience. Replacing the entire logic board can be as easy as 1,2,3 and consume less time. Samsung SPH-A760 Motherboard Replacement
Push Button and no Response
Button is missing
One possibility for no response from the keypad is that some of the buttons from the keypad could be missing. By finding spare parts, you can easily replace the buttons on the keypad to fix this problem. Disassembling Samsung SPH-A760 Keyboard
No Connection
The connection from the keypad to the logic board could have come loose and caused no response in the keypad. By taking the phone apart, you can find out if the keypad needs to be reconnected. If the problem still persists, the wires connecting the keypad could be faulty; buying the appropriate cable could easily fix this problem. Samsung SPH-A760 Motherboard Replacement
Physical Damage
Physical Damage to the keypad could also cause no response in the keypad. The physical damage to the keypad could be so severe that the keypad is malfunctioning and is broken beyond repair. The underside of the keypad could have also been worn out and is not making contact with the logic board. Replacing the entire keypad would be necessary to fix this problem. Samsung SPH-A760 Motherboard Replacement
Problems with Calling/No Reception
Reception problems are the inability to make or receive phone calls and other data.
Antenna is faulty or broken
Reception failure may be the cause of damage to the wireless antenna. A simple inspection of the exterior of the phone may be done to determine if the problem may lie within the circuits of the phone. Samsung SPH-A760 Antenna Replacement
Bad Connection to Antenna
If there is no physical damage to the exterior of the antenna and it is determined that the phone is in a strong signal area, but there the problems with calling and no reception persists, there may be damage to the antenna's connection to the logic board. Samsung SPH-A760 Antenna Replacement
Bad Reception Area/Bad Recipient Reception
Reception problems may also be the result of poor coverage in your area. Normally the phone will display the signal strength of the connection to service towers. Make sure you avoid dead zones to ensure proper signal. Samsung SPH-A760 Antenna Replacement
Charging/Power
Phone doesn't turn on
This may be the cause of an uncharged battery. If the phone runs while connected to the charger then the battery may either be poorly connected or uncharged. Samsung SPH-A760 Battery Replacement
Battery doesn't hold a charge
This happens when the battery is used beyond its optimal operating period. Over time the maximum charge capacity diminishes with use. To avoid this problem, try to ensure that the battery is always fully depleted before you charge it again. The only way to fix this problem is to replace the battery. Samsung SPH-A760 Battery Replacement
The battery is dead, permanently
Only option is to replace battery. Samsung SPH-A760 Battery Replacement
Faulty or broken charging cable
There are a few ways to fix a broken charging cable. The first is to determine if the problem is due to internal wires being disconnected. If this is the problem simply strip the cable to the point where the copper wires are disconnected and solder it together. Then place a heat shrink on that section. If the damage is on the transformer part of the charging cable then the best way to solve this problem is to replace the charging cable with a new one.
Can't Flip Open Properly or Stay open Properly
Hinges are Damaged
The screen on a flip phone when open can be fragile, if the hinges are damaged they can be fixed through our guide. Samsung SPH-A760 Speakers Replacement
Dirt Clogging
Often dirt can impede the operation of the hing which should only require some minor cleaning to fix. Samsung SPH-A760 Speakers Replacement
IF ALL ELSE FAILS
Logic Board
If You have tried all other possibilities on this site, then the logic board is the best guess for the cause of the problem. This means you must replace it or buy a new phone. It isn't possible or advised to try and fix this piece of equipment yourself as the logic board is a complicated piece of equipment that requires knowledge of the internal circuitry and digital design of the hardware. It's not worth the time. Samsung SPH-A760 Motherboard Replacement
Author
with
David
25 Reputation
6 Guides authored
Cal Poly, Team 10-43, Garner Spring 2010 Member of Cal Poly, Team 10-43, Garner Spring 2010
CPSU-GARNER-S10S10G43
5 Members
72 Guides authored
1 Comment
SPH-A760 Device Page
Samsung SPH-A760
Thomas Marderosian - Reply Share
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 10
All Time: 8,197
