Note: This trouble shooting page covers only the Samsung SGH-X495 phone. Earlier and later models may operate differently.
Phone won't turn on
If your phone won’t turn on.
Phone Gone Swimming?
Has the phone been submerged in water?
If this is the case, DO NOT ATTEMPT TO TURN IT ON! Thoroughly dry the phone, open it, remove the battery, and follow the steps to remove front and back casings to expedite the drying process.
Improperly Installed Battery
Your battery may not be properly connected. Check the battery connection points to assure there are no obstructions, and reinstall the battery.
Hold Power Button Longer
Sometimes it takes longer for the phone to start up. Make sure you’re holding down the correct power button, and hold it down for at least 5 seconds. Also check to see if the power button is jammed. If it is jammed refer to the keypad guide.
Drained/Bad Battery
Your battery may not be charged enough to start up, especially if you have not used or charged it in a while. First plug in the phone and turn it on. If it doesn't turn on, then charge the battery with a different charger and try again to turn it on. If the phone still won’t start, try replacing the battery.
Bad Charger
Check to see that the problem is not the charger. Check for the charging symbol on the screen to when plugged into charger. If the phone is not charging check the connection and/or try another outlet. Otherwise try a different charger.
Wiring Problem
The phone may be working but the display wiring is disconnected. Turn the phone on and watch for any lights that turn on and listen for any start up sounds. To ensure that the phone is off, remove the battery and replace it. If there is a display problem, see the Screen guide for how to fix it.
Bad Motherboard / Connection
None of the other checkpoints work?
If you have checked all of the previous suggestions, then your motherboard may need repair or replaced. See the manual for step by step directions on replacing your motherboard.
Screen Problems
You can answer calls, but who knows who they're from. Texts are impossible to read.
Screen Won’t Turn On
The phone is on but the screen is blank
Faulty Wiring
If you dropped your phone, the wiring might be loose. Follow the guide on the motherboard to fix this.
If you dropped the phone in water, you may have damaged the Motherboard. To examine or replace it, follow the guide to the motherboard.
Broken/Cracked Screen
There are layers to the screen; usually the protective screen is all that has broken and this is attached to the faceplate, not the actual LCD screen. See the screen guide to replacing the screen.
Microphone Malfunctioning
Can't be heard on the other end.
Volume Settings
Check the phone settings to assure that the microphone volume has not been turned off.
Bad Wiring
There might be a disconnection in the wiring. To examine this, follow the microphone guide.
Bad Microphone
It is possible that the microphone broke. You can replace it by following the guide to the microphone.
Bad Motherboard
If you replaced your microphone and are still having trouble, the motherboard may be broken. See the manual for step by step directions on reaching/replacing the motherboard.
Speaker Malfunctioning
Experiencing a muffled or tinny sounding speaker? Is there no sound at all?
Volume Settings
Check the phone settings to assure that the speaker volume has not been turned off.
Debris or Loose Wire
There may be debris that have made it into the speaker or simply a loose wire causing the unclear sound. To clean and inspect the wiring, follow the speaker guide.
Bad Speaker
If the speaker has been damaged, and neither cleaning nor fixing/checking the connection doesn't solve it, you can replace it by following the speaker guide.
Defective Motherboard
If you tried cleaning the debris from the speaker, checked the wiring and replaced the speaker, and are still having problems, then it could be a problem with the motherboard. The motherboard may have disconnected wires that you can inspect and reconnect. If the wires are fried or the motherboard is faulty, you can replace the motherboard by following the motherboard guide.
Keypad Malfunctioning
Your keypad is not responding to your entries.
Phone Locked
Your phone may simply be locked. Try to unlock the phone.
Jammed Key(s)
One or more keys may be jammed. This can be fixed by viewing the keypad guide.
Debris / Damage
If the keypad is damaged, then this may cause a problem between the keypad and the motherboard’s internal buttons. To inspect keypad for damage, clean and/or replace the keypad, see guide to the keypad.
If you removed the debris and/or replaced the keypad, and it is still not working properly, you might need to replace the motherboardin order to re-establish a connection with the keypad.
Samara Jackson
15 Reputation
0 Guides authored
Cal Poly, Team 3-40, Regan Winter 2011 Member of Cal Poly, Team 3-40, Regan Winter 2011
CPSU-REGAN-W11S3G40
4 Members
120 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 22
All Time: 2,888
