Samsung SGH-X495 Microphone Replacement
  1. Samsung SGH-X495 Microphone Replacement, Backplate: step 1, image 1 of 1
    • Remove the 4 (4.7mm) philips head screws.
    Ask FixBot
  2. Samsung SGH-X495 Microphone Replacement: step 2, image 1 of 1
    • Unplug the rubber charger outlet cover.
    Ask FixBot
  3. Samsung SGH-X495 Microphone Replacement: step 3, image 1 of 1
    • Unplug the rubber headset jack cover.
    Ask FixBot
  4. Samsung SGH-X495 Microphone Replacement: step 4, image 1 of 2 Samsung SGH-X495 Microphone Replacement: step 4, image 2 of 2
    • Begin by inserting the pry tool near the charger jack.
    • There are 4 tabs to release.
    • Start at the bottom and slide the tool up, lifting the silver front of the phone away from the white backing.
    • Loosen the 2 side tabs before moving on to the top two.
    • See the second photo to see location of the tabs.
    • Be careful of the ribbon wires shown in second photo.
    Ask FixBot
  5. Samsung SGH-X495 Microphone Replacement: step 5, image 1 of 2 Samsung SGH-X495 Microphone Replacement: step 5, image 2 of 2
    • Once the two side tabs are free; gently pry the white backing down to release the top two tabs.
    • Hold the phone with the left hand as shown
    • Wiggle the white backplate from side to side while pulling down with the right hand.
    Ask FixBot
  6. Samsung SGH-X495 Microphone Replacement, Motherboard: step 6, image 1 of 1
    • Remove the ribbon wires connecting to the screen using the pry tool.
    Ask FixBot
  7. Samsung SGH-X495 Microphone Replacement: step 7, image 1 of 1
    • 2 tabs hold the motherboard in place.
    • Release the labeled tabs with the pry tool from the location shown.
    Ask FixBot
  8. Samsung SGH-X495 Microphone Replacement: step 8, image 1 of 1
    • Separate the motherboard from the phone.
    Ask FixBot
  9. Samsung SGH-X495 Microphone Replacement, Microphone: step 9, image 1 of 1
    • Solder joints are accessable to replace the microphone.
    Ask FixBot
Matthew Hove
1,031 Reputation
10 Guides authored
Cal Poly, Team 3-40, Regan Winter 2011 Member of Cal Poly, Team 3-40, Regan Winter 2011
CPSU-REGAN-W11S3G40
4 Members
32 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 40
All Time: 2,206
