Samsung SGH-X495 Face Plate Replacement
  1. Samsung SGH-X495 Face Plate Replacement, Face Plate: step 1, image 1 of 1
    • First, remove the 2 silver stickers (as indicated by the circles) with a a safety or push pin to reveal 2 screws.
    Ask FixBot
  2. Samsung SGH-X495 Face Plate Replacement: step 2, image 1 of 1
    • Remove the 2 (5.6 mm) philips head screws with your safety or push pin.
    Ask FixBot
  3. Samsung SGH-X495 Face Plate Replacement: step 3, image 1 of 2 Samsung SGH-X495 Face Plate Replacement: step 3, image 2 of 2
    • As shown above, with a plastic pry tool, begin working at the top corner and down each side. The face plate has 10 tabs that hook into the phone's body.
    • Before removing the 2 tabs on the bottom, the 3 tabs on either side must be free first.
    • Note: The bottom 2 are the most challenging to remove.
    • Note: When reassembling start with the bottom two tabs.
    Ask FixBot
  4. Samsung SGH-X495 Face Plate Replacement: step 4, image 1 of 2 Samsung SGH-X495 Face Plate Replacement: step 4, image 2 of 2
    • Continue down each side toward the bottom with your pry tool.
    • Note: It may help to use multiple pry tools to help hold it open.
    • Second photo: location of the tabs.
    Ask FixBot
  5. Samsung SGH-X495 Face Plate Replacement: step 5, image 1 of 2 Samsung SGH-X495 Face Plate Replacement: step 5, image 2 of 2
    • With 8 tabs released, the face plate is nearly free.
    • With the phone in your left hand, gently wiggle the face plate from side to side and push the face place upward.
    • Note: A strip of double sided tape holds the faceplate, so expect some resistance
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Matthew Hove
1,031 Reputation
10 Guides authored
Cal Poly, Team 3-40, Regan Winter 2011 Member of Cal Poly, Team 3-40, Regan Winter 2011
CPSU-REGAN-W11S3G40
4 Members
32 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 37
All Time: 2,502
