Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Camera Won’t Turn On
Battery Is Not Charged
The battery might not be charged. Remove the battery and plug it into the charger to fix this. If this does not fix the problem, the battery may need to be replaced.
Battery Is Not Oriented Properly
The battery might not be input properly in its chamber. Check the Samsung DV300F User Manual to ensure the battery is input properly.
Back LCD Screen Is Cracked
Back LCD Screen Is Damaged
Remove the back LCD screen and replace it with a new one using this replacement guide. Ensure your replacement screen is the right one for this camera.
Battery Won’t Charge
Battery Is Broken
The battery might be old or damaged and require a replacement. Acquire a new battery and replace the current one. Ensure the battery is input properly in its chamber. Make sure it's the correct type of battery for the specific device. We recommend you purchase the replacement battery from Samsung.
Charger Is Broken
The charger might be old or damaged and require a replacement. Acquire a new charger for the battery. Be sure to purchase the proper charger. We recommend you purchase this item from Samsung.
Flash Does Not Work
Flash Is Off
The flash may not be turned on. Go to the settings menu on the camera and turn the flash on. For additional help with this, consult the Samsung DV300F User Manual.
Flash Bulb Is Burnt Out or Damaged
The flash bulb is perhaps no longer functioning. Buy a replacement flash bulb that is compatible with the Samsung DV300F and replace your current one with it.
Case Is Cracked
Case Is Damaged
Remove the case and replace it using this replacement guide. You will want to purchase a new case from Samsung for this particular device to ensure that it will fit properly.
Lens Will Not Retract or Respond
Lens Is Dirty
There may be dirt or debris around the lens that prevent it from moving. Clean around the edge of the lens to remove any dirt or debris.
Lens Is Broken
The lens mechanism may need to be replaced. Replace the lens mechanism using this replacement guide. Be sure to purchase the proper lens from Samsung to ensure that it will fit and work properly.
LCD Screen Won’t Turn On (Front or Back)
LCD Screen Is Not Attached to Circuit Board
The LCD screen might not be completely attached to the circuit board. Check this replacement guide for the back LCD screen or this replacement guide for the front LCD screen to verify its plugin.
LCD Screen Is Broken
The LCD screen might be damaged internally and require a replacement. Use this replacement guide for the back LCD screen or this replacement guide for the front LCD screen to replace it. Be sure to purchase a replacement from Samsung to ensure it will work properly.
Pictures or LCD Image Is Blurry or Obscure
Lens Is Dirty
The lens might simply be dirty. Clean the lens with a soft cloth, such as a lens cloth or tissue paper. Dampen the cloth with water if the debris is stuck to the lens.
Lens Is Damaged or Broken
The lens might be damaged internally and require a replacement. Use this lens replacement guide to replace it. Be sure to replace it with the exact same lens from Samsung to ensure it fits and works properly.
Rear Buttons are Not Responding
Rear Button Control Board Is Not Attached to Circuit Board
The rear button control board might be disconnected from its port in the circuit board. Check out this replacement guide to verify its plugin.
Rear Button Control Board Is Damaged or Broken
The rear button control board might need to be replaced due to damage to the board itself. Check out this replacement guide to replace it. Be sure that your replacement is made for the Samsung DV300F.
Top Buttons are Not Responding
Top Button Unit Is Damaged or Broken
The top button unit might need to be replaced due to internal damage to the unit or damage to a specific button. Acquire a replacement and swap it out with your current one. Be sure that your replacement is for the Samsung DV300F.
Author
with
Timothy Gordon
874 Reputation
5 Guides authored
Baylor, Team 5-10, Williams Spring 2015 Member of Baylor, Team 5-10, Williams Spring 2015
BU-WILLIAMS-S15S5G10
3 Members
60 Guides authored
3 Comments
I am unable to post photos on to facebook, it keeps saying no response from server can you help please .I use to be able to.
Emily - Reply Share
I have a problem with my camera .
It is from 1 month problem..my camera is showing a red line vertically when I am shooting photo. And the major problem is the line is appearing in clicked photo also…
Please reply to me what to do.??
VK creations - Reply Share
minha camera precisei substituir o bloco optico e agora não está mais focando , preciso do arquivo de adjustes onde consigo?
jorge carlos TACÃO - Reply Share
Past 24 Hours: 4
Past 7 Days: 8
Past 30 Days: 65
All Time: 4,067
