Samsung DV300F Front LCD Screen Replacement
    1. Samsung DV300F Front LCD Screen Replacement, Front and Rear Casing: step 1, image 1 of 3 Samsung DV300F Front LCD Screen Replacement, Front and Rear Casing: step 1, image 2 of 3 Samsung DV300F Front LCD Screen Replacement, Front and Rear Casing: step 1, image 3 of 3
      • Remove the two black 4.2 mm screws on the right side of the camera using a Phillips #0 screwdriver.
      • Remove the two black 4.2 mm screws on the left side of the camera using a Phillips #0 screwdriver.
      • Remove the two black 4.2 mm screws on the bottom of the camera using a Phillips #0 screwdriver.
      Ask FixBot
    2. Samsung DV300F Front LCD Screen Replacement: step 2, image 1 of 2 Samsung DV300F Front LCD Screen Replacement: step 2, image 2 of 2
      • Remove the back case of the camera carefully.
      Ask FixBot
    3. Samsung DV300F Front LCD Screen Replacement: step 3, image 1 of 3 Samsung DV300F Front LCD Screen Replacement: step 3, image 2 of 3 Samsung DV300F Front LCD Screen Replacement: step 3, image 3 of 3
      • Remove the front case of the camera.
      • Remove the front LCD screen from the front case next to the lens.
      Ask FixBot
    1. Samsung DV300F Front LCD Screen Replacement, Back Button Control: step 4, image 1 of 2 Samsung DV300F Front LCD Screen Replacement, Back Button Control: step 4, image 2 of 2
      • Remove the blue button control from its position next to the LCD screen.
      • Pull the ribbon cable to disconnect the blue button control from the camera.
      Ask FixBot
    1. Samsung DV300F Front LCD Screen Replacement, Back LCD Screen: step 5, image 1 of 1
      • Remove the back LCD screen from its place carefully.
      Ask FixBot
    2. Samsung DV300F Front LCD Screen Replacement: step 6, image 1 of 2 Samsung DV300F Front LCD Screen Replacement: step 6, image 2 of 2
      • Flip the black tab where the back LCD screen connects to the circuit board.
      • Pull the tape connection to disconnect the back LCD screen from the circuit board.
      Ask FixBot
    1. Samsung DV300F Front LCD Screen Replacement, Front LCD Screen: step 7, image 1 of 2 Samsung DV300F Front LCD Screen Replacement, Front LCD Screen: step 7, image 2 of 2
      • Unscrew the 3 silver 4.5 mm screws from the circuit board using a Phillips #0 screwdriver.
      • Remove the circuit board cover.
      Ask FixBot
    2. Samsung DV300F Front LCD Screen Replacement: step 8, image 1 of 3 Samsung DV300F Front LCD Screen Replacement: step 8, image 2 of 3 Samsung DV300F Front LCD Screen Replacement: step 8, image 3 of 3
      • Flip the black tab where the front LCD screen connects to the circuit board.
      • Pull the tape connection to disconnect the front LCD screen from the circuit board.
      • You can do this easily with your fingers.
      • Remove the front LCD screen from the front of the camera.
      Ask FixBot
Timothy Gordon
874 Reputation
5 Guides authored
Baylor, Team 5-10, Williams Spring 2015 Member of Baylor, Team 5-10, Williams Spring 2015
BU-WILLIAMS-S15S5G10
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 55
All Time: 1,539
