Up to 20% off select tools
Samsung DV300F Back LCD Screen Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
110
All Time:
2,132
Comments: 6
6 comments on steps.
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
This guide will show how to remove the Back LCD Screen.
    1. Samsung DV300F Back LCD Screen Replacement, Front and Rear Casing: step 1, image 1 of 3 Samsung DV300F Back LCD Screen Replacement, Front and Rear Casing: step 1, image 2 of 3 Samsung DV300F Back LCD Screen Replacement, Front and Rear Casing: step 1, image 3 of 3
      • Remove the two black 4.2 mm screws on the right side of the camera using a Phillips #0 screwdriver.
      • Remove the two black 4.2 mm screws on the left side of the camera using a Phillips #0 screwdriver.
      • Remove the two black 4.2 mm screws on the bottom of the camera using a Phillips #0 screwdriver.
      Ask FixBot
    2. Samsung DV300F Back LCD Screen Replacement: step 2, image 1 of 2 Samsung DV300F Back LCD Screen Replacement: step 2, image 2 of 2
      • Remove the back case of the camera carefully.
      Ask FixBot
    3. Samsung DV300F Back LCD Screen Replacement: step 3, image 1 of 3 Samsung DV300F Back LCD Screen Replacement: step 3, image 2 of 3 Samsung DV300F Back LCD Screen Replacement: step 3, image 3 of 3
      • Remove the front case of the camera.
      • Remove the front LCD screen from the front case next to the lens.
      Ask FixBot
    1. Samsung DV300F Back LCD Screen Replacement, Back LCD Screen: step 4, image 1 of 1
      • Remove the back LCD screen from its place carefully.
      Ask FixBot
    2. Samsung DV300F Back LCD Screen Replacement: step 5, image 1 of 2 Samsung DV300F Back LCD Screen Replacement: step 5, image 2 of 2
      • Flip the black tab where the back LCD screen connects to the circuit board.
      • Pull the tape connection to disconnect the back LCD screen from the circuit board.
      Ask FixBot
5 other people completed this guide.
Author
with
Timothy Gordon
874 Reputation
5 Guides authored
Baylor, Team 5-10, Williams Spring 2015 Member of Baylor, Team 5-10, Williams Spring 2015
BU-WILLIAMS-S15S5G10
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 110
All Time: 2,132
