Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
No Sound Coming from Speakers
The sender and receiver units are connected but there is no sound coming from the speakers.
Faulty AC Adapter Connection
Make sure that the AC Adapter is connected to the sender and the cord is connected to the AC supply for the receiver.
Faulty Cable Connections
Make sure that all the cables are connected correctly. The sender is for the speaker wire input and the receiver is for the speaker wire output. Also, check to see if your speaker wires are operating properly. If the cables are connected correctly and there is still no sound, the sender may have a faulty speaker wire input. Consider replacing the speaker wire input panel.
If the LEDs are lit solidly on both the sender and receiver, then the communication is working properly and sound should be coming out of the speakers. If the LEDs are functioning improperly, refer to the section "LED Light Not Working Properly".
Sound Interference
There is sound coming from the speakers, but it is fuzzy or unclear.
Improper Distance Between Sender and Receiver
Move the sender and receiver to find the best distance for your system. The maximum distance between the sender and receiver is 100 feet. Shorten the distance between the devices if they are further apart.
Nearby Radio Frequency Disruption
Move the devices away from any obvious radio frequency sources.
No Communication Between Sender and Receiver
The sender and receiver are not connecting/communicating.
Faulty Power Cord Connection
Be sure that the power cords are solidly connected to the devices and outlets.
Weak Device Connection
After the sender and receiver have both been turned on, each of their LEDs indicators should be lit. If they are solidly lit, then the devices have been successfully connected. Flashing LEDs on one or both units, indicate sender/receiver is not successfully connected. To fix this, press the "connect" button on the bottom of the sender or receiver and hold for 2 seconds (units are now in connection mode for about 30 seconds). Once one unit is in connect mode, repeat for the second device. If the units are unresponsive to pressing the connect button, there may be an issue with either the sender or receiver's wireless connection. Consider replacing the receiver wireless audio module chip or replacing the sender wireless audio module chip. The LEDs blink more rapidly when the devices are connecting. Once the LEDs are solidly lit, the sender and receiver have been connected. If after 30 seconds the LEDs are still blinking, press the connect buttons again. If the one or both of the LED lights is not working, refer to the section "LED Light Not Working Properly".
Indicator LED light on either the sender or receiver will not light up/is functioning improperly.
Faulty LED Light Chip
Make sure the device is properly plugged in and turned on. If the LEDs are solidly lit, then the devices are connected. If the LEDs are blinking on one or both units, the sender and receiver are not successfully connected. Refer to the section "No Communication Between Sender and Receiver" for information on how to successfully connect your devices. Rapidly blinking LEDs indicate that the devices are connecting. This should not last longer than 30 seconds. If the LED(s) is performing differently from these normal functions or will not light up, it could indicate a problem with the LED light chip inside the device. If the LED on the receiver is not lit or is functioning improperly, consider replacing the receiver LED light chip.
Author
with
Logan Brown
1 Reputation
0 Guides authored
Baylor, Team 4-2, Williams Spring 2015 Member of Baylor, Team 4-2, Williams Spring 2015
BU-WILLIAMS-S15S4G2
3 Members
72 Guides authored
21 Comments
I have tried the 2 second count on both the sender and receiver several time but the light on the receiver will not stay lit and will not sink with the sender. Can you help what should I try next?
egosline - Reply Share
I had this problem as well I couldn't figure it out! I finally went to unplug it to return it back to bestbuy and realized one of my speaker wires for my rear speakers were disconnected. Not at the receiver but on my actual speaker. Worked perfectly after 2 months of not working!
narcoticbmx - Reply Share
I can get stereo but not surround sound…please tell me what i’m doing wrong.
Thank you in advance.
Keith Rolfe - Reply Share
I have both led lights working but no sound?
William Banning - Reply Share
Both led lights (sender and receiver) are blue and steady but no sound. Should the source light be lit? I have read the manual and troubleshooting instructions over and over but cannot get sound.
shirley sanford - Reply Share
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 105
All Time: 26,754
