Up to 20% off select tools
Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement
Views: 2.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
95
All Time:
2,887
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Tools
Introduction
Go to step 1 ↓
A sender that is unresponsive in connection mode may indicate a problem with the wireless connection chip within the device. Replacing a faulty chip can help restore the device's function. This guide will help users replace a faulty wireless module chip indicated by an unresponsive connection between the sender and receiver devices.
    1. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement, How to Open the Rocketfish RF-WHTIB-A Receiver: step 1, image 1 of 1
      • Remove the 4 rubber tabs on the bottom side of the receiver.
      Ask FixBot
    2. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: step 2, image 1 of 1
      • Unscrew the four 12 mm screws on the bottom side of the receiver.
      • Use a Phillips #1 screwdriver for this step.
      Ask FixBot
    3. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: step 3, image 1 of 2 Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: step 3, image 2 of 2
      • Remove top casing from the receiver.
      • The receiver top casing is difficult to remove. Internal clasps may have to be broken in order to remove the top casing (this will not effect the device's function)
      Ask FixBot
    1. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement, Receiver Wireless Audio Module Chip: step 4, image 1 of 1
      • Unscrew the 10 mm screw holding the wireless audio module.
      Ask FixBot
    2. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: step 5, image 1 of 2 Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Slide the black retaining flap securing the ribbon cable away from the white bar.
      • There should be only a small space between the white bar and black retaining flap.
      • You may want to use tweezers for this step.
      Ask FixBot
    3. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: step 6, image 1 of 1
      • Using your fingers, slide the ribbon cable out from the under the black retaining flap to completely disconnect it from the device.
      Ask FixBot
To install the new wireless audio module chip, follow these instructions in reverse order.
2 other people completed this guide.
Author
with
Caitlin Charlton
807 Reputation
6 Guides authored
Baylor, Team 4-2, Williams Spring 2015 Member of Baylor, Team 4-2, Williams Spring 2015
BU-WILLIAMS-S15S4G2
3 Members
72 Guides authored
1 Guide Comment
This is a very long time later, but where do you get the receiver chip??? Rocket fish doesn't support the product anymore
Michael Jay - Reply Share
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 95
All Time: 2,887
