Up to 20% off select tools
Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
92
All Time:
2,810
Comments: 4
1 comment on steps, 3 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
Introduction
Go to step 1 ↓
An LED light not working on the Rocketfish RF-WHTIB-A receiver does not necessarily mean the entire device is broken. It could indicate a problem with the LED light chip inside the device, which controls the LED light function. This guide will direct users step by step to replacing a faulty LED light chip.
    1. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement, How to Open the Rocketfish RF-WHTIB-A Receiver: step 1, image 1 of 1
      • Remove the 4 rubber tabs on the bottom side of the receiver.
      Ask FixBot
    2. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement: step 2, image 1 of 1
      • Unscrew the four 12 mm screws on the bottom side of the receiver.
      • Use a Phillips #1 screwdriver for this step.
      Ask FixBot
    3. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement: step 3, image 1 of 2 Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement: step 3, image 2 of 2
      • Remove top casing from the receiver.
      • The receiver top casing is difficult to remove. Internal clasps may have to be broken in order to remove the top casing (this will not effect the device's function)
      Ask FixBot
    1. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement, Receiver LED Light Chip: step 4, image 1 of 2 Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement, Receiver LED Light Chip: step 4, image 2 of 2
      • One 10 mm screw is securing the LED 14.14 chip.
      • Unscrew the chip.
      • Use a Phillips #1 Screwdriver for this step.
      Ask FixBot
    2. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement: step 5, image 1 of 1
      • Using your fingers, gently pull the LED plug out of the mother board.
      Ask FixBot
    3. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Gently feed the LED wire under the power supply to completely remove it from the sender.
      • Remove the faulty LED 14.14 chip from the receiver.
      • You may want to use the tweezers to help pull the LED wire out from beneath the power supply.
      Ask FixBot
To reassemble your device with the new LED light chip, follow these instructions in reverse order.
Once the receiver has been put back together, plug in the device and initiate the connection mode between the sender and receiver to ensure the new LED light chip has been properly assembled.
Author
with
Caitlin Charlton
807 Reputation
6 Guides authored
Baylor, Team 4-2, Williams Spring 2015 Member of Baylor, Team 4-2, Williams Spring 2015
BU-WILLIAMS-S15S4G2
3 Members
72 Guides authored
3 Guide Comments
Where do I get the chip???
sean moore - Reply Share
where do I get chip?
bugsyc26 - Reply Share
The clear plastic light guide fell out and having trouble figuring out where it goes.
Graeme Elliott - Reply Share
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 92
All Time: 2,810
