Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Hair Dryer Fails to Turn On
Revlon One-Step Hair Dryer will not power on once it is plugged in.
Switch is not on correct setting
If the hair dryer fails to turn on after being plugged in, make sure the switch is on the correct setting. There are four settings: off, cool, low, and high. In order for the dryer to power on, place the switch on the cool, low, or high setting.
Broken Setting Dial
If the dryer still fails to power on after using one of the three settings: cool, low, or high, the setting dial may need to be replaced. To change the setting dial, check out the setting dial replacement guide.
Defective Plug
After multiple attempts, if the hair dryer still does not power on, there may be a problem with the cord and plug. Before turning the hair dryer on, push the reset button on the plug. If the dryer still fails to turn on after following these steps, the dryer's cord/plug may need to be replaced. Check out the cord and plug replacement guide for instructions regarding this issue.
Burnt Smell
The hair dryer produces an unusual smell.
Dryer is Overheating
If the dryer generates a burnt scent after it is turned on, turn the switch to the off setting and unplug it from the outlet immediately. Once unplugged, allow the hair dryer to cool down for approximately five minutes, then turn it back on.
Blocked Lint Filter
If the burning smell persists, it could possibly mean the lint filter is blocked and needs to be cleaned. Check out the Lint Filter Replacement guide in order to properly clean the filter and potentially fix the burning smell.
Overheating
Hair dryer is extremely hot to the touch.
Dirty Air Inlet
If the dryer overheats while it is on, there may be an issue with excess lint getting into the air inlet. When the inlet is blocked, the fan cannot blow cool air efficiently to balance the hot air being blown out. If this problem persists, refer to the air inlet replacement guide.
Defective Thermal Cutoff Switch
When the thermal cutoff switch is malfunctioning, it will most likely cause the hair dryer to overheat. Contrastingly, when the thermal cutoff switch is properly functioning, it does not allow the temperature to exceed its limit. Therefore, the thermal cutoff switch may need to be replaced.
Distorted Noise
The hair dryer is making a peculiar noise.
Loose Propeller
If the dryer is making a rattling noise while being used, there may be an issue with the propeller. You may have to either tighten the propeller, or replace it. To solve this issue you can reference our Propeller Repair guide.
Not Blowing Hot Air
The heat does not work when the dryer is turned on.
On the Incorrect Setting
Because there are four settings: off, cool, low, and high, the dryer could be on the wrong setting. Ensure that the dryer is placed on the low or high setting instead of the cool setting.
Faulty Fuses
If the dryer does not blow hot air while placed on the low or high setting, there may be an issue with the fuse. The hair dryer uses two fuses; if one of the fuses breaks, the drum may still spin, but will not diffuse hot air. Therefore, both fuses will need to be replaced simultaneously. For information on how to repair this, refer to our Fuse Repair guide.
Faulty Heating Element
Because the heating element allows the dryer to blow hot air, this may be the source of the problem. If the dryer fails to blow hot air after multiple attempts, the heating element most likely needs to be replaced.
Insufficient Air Flow
The hair dryer has a limited air flow when turned on.
Defective Barrel
The barrel is a vital source for air flow. Some reasons why the barrel may need to be replaced could be due to a build up of a variety of debris such as dust, hair, or even hair protectants/sprays. To replace the barrel, check out the barrel replacement guide.
Clogged Lint Filter
The lint filter is a very important aspect of the hair dryer because this filter is what purifiers all of the debris out of the air that comes through the air inlet. If the lint filter is damaged it could lead to potential debris buildup within the hair dryer, which could restrict air flow. To replace the filter, check out the lint replacement guide.
12 Comments
I Plugged it into a 220V outlet and it was rated for 110V, can it be fixed
varun yadav - Reply Share
Mine does not throw cold air at any setting. I don't know if it's how it supposed to be or the heat dial has a problem.
Usama Shah - Reply Share
The switch on mine is stuck in the middle, don't know how to fix it.
alEinstien - Reply Share
Can’t steam to get the brush to stay on the barrel
cherduncman - Reply Share
Mine is brand new and has this burn nasty smell, leaves hair and my whole house with burn smell.
verom_88 - Reply Share
Past 24 Hours: 9
Past 7 Days: 77
Past 30 Days: 370
All Time: 67,786
