Revlon One-Step Hair Dryer Setting Dial Replacement
Views: 7.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
24
Past 30 Days:
127
All Time:
7,210
Comments: 17
15 comments on steps, 2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 35 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your hair dryer will not power on after multiple troubleshooting attempts, the setting dial may be defective. As a result, this guide will instruct users on how to properly replace the setting dial at the bottom of the hair dryer.
Tools
    1. Revlon One-Step Hair Dryer Setting Dial Replacement, Barrel: step 1, image 1 of 1
      • First, remove the pink panels on each side of the handle in order to access the screws.
      • Use the iFixit opening tool to remove the pink panels.
      Ask FixBot
    2. Revlon One-Step Hair Dryer Setting Dial Replacement: step 2, image 1 of 3 Revlon One-Step Hair Dryer Setting Dial Replacement: step 2, image 2 of 3 Revlon One-Step Hair Dryer Setting Dial Replacement: step 2, image 3 of 3
      • After removing the pink panels, there will be one visible screw on each side of the dryer handle measuring at 11mm.
      • Carefully unscrew both of these screws with a tri-point Y000 screwdriver.
      • Next, completely remove the screws out of the dryer handle.
      Ask FixBot
    3. Revlon One-Step Hair Dryer Setting Dial Replacement: step 3, image 1 of 3 Revlon One-Step Hair Dryer Setting Dial Replacement: step 3, image 2 of 3 Revlon One-Step Hair Dryer Setting Dial Replacement: step 3, image 3 of 3
      • Remove the barrel by twisting and pulling it away from the handle of the dryer.
      • Before attempting to take the barrel off, make sure the dryer powered completely off and is cool to the touch.
      Ask FixBot
    1. Revlon One-Step Hair Dryer Setting Dial Replacement, Cord and Plug: step 4, image 1 of 2 Revlon One-Step Hair Dryer Setting Dial Replacement, Cord and Plug: step 4, image 2 of 2
      • Next, slide down the air inlet and the setting dial to reveal the 11mm screws on each side of the handle at the bottom of the hair dryer.
      Ask FixBot
    2. Revlon One-Step Hair Dryer Setting Dial Replacement: step 5, image 1 of 1
      • There will be one visible screw on each side of the dryer at the bottom of the handle, measuring at 11mm.
      • Store screws in a safe place, you will need them to reassemble the device later.
      Ask FixBot
    3. Revlon One-Step Hair Dryer Setting Dial Replacement: step 6, image 1 of 1
      • Place the iFixit opening tool along the seams of the handle and pry the two pieces apart.
      Ask FixBot
    4. Revlon One-Step Hair Dryer Setting Dial Replacement: step 7, image 1 of 3 Revlon One-Step Hair Dryer Setting Dial Replacement: step 7, image 2 of 3 Revlon One-Step Hair Dryer Setting Dial Replacement: step 7, image 3 of 3
      • Once you have exposed the inside of the dryer, you will see a clear port at the very end where the cord is connected and plugged into.
      • Now, with your thumb and pointer finger gently pinch the top and bottom of the clear port.
      • Next with your free hand carefully pull the cord out of the port of the dryer handle.
      Ask FixBot
    1. Revlon One-Step Hair Dryer Setting Dial Replacement, Setting Dial: step 8, image 1 of 1
      • Once the cord is disconnected from the handle, you should be able to slide the dial setting off completely and free it from the cord.
      Ask FixBot
2 other people completed this guide.
2 Guide Comments
Referring to step 4, how do you release the first part with the metal mesh inside from the body
Richard Funnell - Reply Share
This video shows very good how to dissamble the hairdryer. https://youtu.be/Qc-jcJbNQzE?si=wibfeCDW...
Tobi - Reply Share
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 127
All Time: 7,210
