Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Keyboard is broken
Your keyboard is sticky, not responding, or is missing keys.
Sticky keys
Here are three easy solutions; First power the PC off, then use a warm damp washcloth to clean the keys (allow to dry before turning power back on). Next, try using a can of compressed air to clear stuck debris from under the keys. Lastly, you could simply lift and tilt the PC so the keys are facing down and shake lightly.
Faulty Keyboard
First you will need a small-thin flat head screwdriver to get faulty keys of keyboard. Next click here for how to replace with new keys.
Missing keys
First start out by getting some replacement keys for your specific keyboard. Next follow the guide link provided to the Faulty Keyboard guide for more information on how to replace the keys. Razer Blade RZ09-0102 Keyboard Keys Replacement
Loud noises are coming from my computer
There is a weird or loud noise coming from the computer.
Loud fan
First start with powering off the laptop. Next you should open the laptop from the rear. Click here for a guide on how to open the rear of the computer. Then you will need a compressed air can to clean off the fans. If a compressed air can is not available, then you can use a damp paper towel or rag. DO NOT USE A SOAKING WET RAG OR DAMAGE WILL OCCUR.
Faulty fan
First power off the laptop. Next follow the guide here to open the back of the laptop to replace the faulty fan. Razer Blade RZ09-0102 Fan Replacement
My laptop keeps shutting down
Oh no! Your laptop keeps shutting off on you.
Charge
First check for a charge make sure the power cord is plugged into a working power outlet. Next check to see if the power cable is clear of debris. Plug cable into laptop and see if charging light turns on.
Restart
Simply restart the computer via restart button to see if it resolves the issue.
Replacing battery
First, make sure that the laptop's battery is completely drained of power for safety. Next, click here to see how to remove the back of the laptop as well as how to replace the battery. Razer Blade RZ09-0102 Battery Replacement
My laptop will not turn on
Your computer is not turning on.
Battery Status
First make sure the power cord is plugged into a working power outlet. Next check to see if the power cable is clear of debris. Plug cable into laptop and see if charging light turns on.
Dead battery
First, make sure that the laptop's battery is completely drained of power for safety. Next, click here to see how both remove the back of the laptop and how to replace its battery.
Broken charging port
If the previous steps did not solve the issue, the laptop port for charging the battery may be ruined or have a bad connection
Distorted Audio
Your laptops audio sounds different or funny.
Faulty Speakers
First you will need to remove the back of the laptop to gain access to the speaker, here is a guide on how to open it. Then check to see if there are any faulty wires connected to the speakers and if so here is a guide to replace them. If the wiring is fine then it is a problem with the speaker itself and will need replaced. Here is a guide on how to replace them.
Razer Blade RZ09-0102 Speakers Replacement
Laptop overheating
" Your laptop keeps overheating or gets hot way to quickly. "
Faulty Heat Pipe
First you will need to make sure the laptop is powered down. Next remove the backing of the laptop. After this you will need to remove the bronze colored Heat Pipes that run the length of the laptop. Here is a guide on how to safely remove them. Razer Blade RZ09-0102 Heat Pipe Replacement
Laptop Systems not working
" The laptop will not open applications or recessive commands from the user. "
Faulty Motherboard
First make sure the laptop is turned off. Next you will need to remove the back casing. Following that you will need to follow this guide to remove the motherboard from the laptop.
Razer Blade RZ09-0102 Motherboard Replacement
0 Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 25
All Time: 2,295
