Razer Blade RZ09-0102 Fan Replacement
Views: 7.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
65
All Time:
7,180
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 8 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The fans in your laptop are important for keeping the internal components from overheating. So it's important to preform maintenance on them to keep your laptop working properly. Whether to replace the fans or just removing them to clean is up to you. The fans are also required to be removed if working on some other components in this device. The fans in this device are 7 x 7 CM.
Tools
    1. Razer Blade RZ09-0102 Fan Replacement, Rear Panel: step 1, image 1 of 1
      • Before you begin, be sure to turn off your laptop.
      • Using a Torx T5 screwdriver, remove the ten 1/8 inch screws securing the back cover.
      • Remove the back cover.
      Ask FixBot
    1. Razer Blade RZ09-0102 Fan Replacement, Fan: step 2, image 1 of 1
      • Remove the three black rubber pads that cover the screws holding the fan.
      Ask FixBot
    2. Razer Blade RZ09-0102 Fan Replacement: step 3, image 1 of 1
      • Use the Phillips #0 screwdriver to remove the three 1/4 inch screws.
      Ask FixBot
    3. Razer Blade RZ09-0102 Fan Replacement: step 4, image 1 of 1
      • Disconnect the wire that goes from the fan into the white connector, but leave the wire attached to the fan.
      Ask FixBot
    4. Razer Blade RZ09-0102 Fan Replacement: step 5, image 1 of 2 Razer Blade RZ09-0102 Fan Replacement: step 5, image 2 of 2
      • Lift the fan out with your hands.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 65
All Time: 7,180
