Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Tablet won't turn on
No matter what you do, you can't get your tablet to turn on.
Faulty Power Button
If no audible "click" is heard when pressing the power button to power up the tablet, the button may be broken and will need to be replaced. See the following guide for replacement steps.
Faulty Battery
If the tablet will only power up when it is plugged into the charger, regardless of charging time, there may be a faulty battery. See the following guide to replace your battery.
Faulty Power Adapter
If the power adapter is plugged in, but the device does not indicate any increase in charge and does not register the device being plugged in, the power adapter is faulty. Purchase a new replacement adapter (charger) to continue using the device.
Tablet will not register touch commands
Tablet won't respond to user's touch
Software Issue
If the screen is unresponsive, reboot the tablet. If the tablet then registers touch commands, it was a software error and should continue to function.
Faulty Touch Screen
If after restarting the tablet, it still does not register any touch commands, the touch screen will need to be replaced, see the following guide for replacement steps.
Volume button does not respond
Can't change the volume
Sticky Residue On or Under the Button
Clean the button with rubbing alcohol. This should help to remove any obstructions and sticky material from the button. Also try using a pin or toothpick to scrape away any residue that has collected around the button.
Volume Button Can Not be Pressed
If you are having trouble pressing the button there may be something below the button obstructing the movement. Remove the button and clean any debris or residue that exists below the button with a cotton swab.
Author
with
mikayla
408 Reputation
2 Guides authored
Clemson, Team 14-4, Shirley Spring 2015 Member of Clemson, Team 14-4, Shirley Spring 2015
CLEM-SHIRLEY-S15S14G4
6 Members
120 Guides authored
5 Comments
my tablet goes on but as far as the two dog logo then thats it nothing
Tina Peters - Reply Share
why my RCA tablet not working the 2 dogs is still in front not moving any more what can i do
ferdzruiz - Reply Share
I don't think mine is working, when it gets to the two dogs, they look at me and then run away ,where do they go?
eblaylock81 - Reply Share
Have no control and on screen wipe it out n reboot but it still comes back to no command
donnawiebner - Reply Share
I keep getting a settings lock on mine even when j factory reset. What can I do
codymcneil4 - Reply Share
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 15
All Time: 1,143
