Up to 20% off select tools
RCA RCT6378W2 Screen Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
Past 7 Days:
2
Past 30 Days:
18
All Time:
1,555
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 45 minutes
Difficulty: Moderate
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
In Progress
This guide is a work in progress. Reload periodically to see the latest changes!
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
If the screen of the device becomes cracked or stops registering touch commands, use the following guide to replace the screen.
    1. RCA RCT6378W2 Screen Replacement, Screen Replacement: step 1, image 1 of 1
      • Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver.
      Ask FixBot
    2. RCA RCT6378W2 Screen Replacement: step 2, image 1 of 2 RCA RCT6378W2 Screen Replacement: step 2, image 2 of 2
      • Remove back cover with lever tool, exposing the battery and motherboard.
      Ask FixBot
    3. RCA RCT6378W2 Screen Replacement: step 3, image 1 of 2 RCA RCT6378W2 Screen Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Using the tweezers, remove the black tape connecting the screen to the motherboard.
      Ask FixBot
    4. RCA RCT6378W2 Screen Replacement: step 4, image 1 of 2 RCA RCT6378W2 Screen Replacement: step 4, image 2 of 2
      • Pull up the switch to remove the input connector.
      Ask FixBot
    5. RCA RCT6378W2 Screen Replacement: step 5, image 1 of 1
      • Heat the iOpener in the microwave, following the instructions provided with the tool. Lay the heated iOpener on the front screen for two minutes to soften the connection of the screen to the tablet.
      Ask FixBot
    6. RCA RCT6378W2 Screen Replacement: step 6, image 1 of 2 RCA RCT6378W2 Screen Replacement: step 6, image 2 of 2
      • Use the suction cup and lever tool tool to pry the front screen from the tablet.
      Ask FixBot
2 other people completed this guide.
Author
with
mikayla
408 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 18
All Time: 1,555
