Up to 20% off select tools
RCA RCT6378W2 Power Button Replacement
Views: 4K
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
82
All Time:
4,005
Comments: 1
1 guide comment.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the power button on your RCA RCT6378W2 if it is not functioning properly.
Verify that the power button needs to be replaced by ensuring that the device charger is functioning properly, and that the battery has a charge.
Before beginning, make sure the device is powered off.  This may require allowing the battery to drain if power cannot be shut off manually due to the malfunctioning power button.  Make sure the device is not connected to any external power source.
    1. RCA RCT6378W2 Power Button Replacement, Power Button: step 1, image 1 of 2 RCA RCT6378W2 Power Button Replacement, Power Button: step 1, image 2 of 2
      • Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver
      • Remove back cover with plastic opening tool to access the power button.
      Ask FixBot
    2. RCA RCT6378W2 Power Button Replacement: step 2, image 1 of 2 RCA RCT6378W2 Power Button Replacement: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Remove and replace the power button using tweezers.
      • Install in reverse order of removal.
      Ask FixBot
7 other people completed this guide.
Author
with
mikayla
408 Reputation
2 Guides authored
Clemson, Team 14-4, Shirley Spring 2015 Member of Clemson, Team 14-4, Shirley Spring 2015
CLEM-SHIRLEY-S15S14G4
6 Members
120 Guides authored
1 Guide Comment
You are the best!!
Thank You, Thank You, Thank You!!
Michael Stephenson - Reply Share
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 82
All Time: 4,005
