Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
SmartFeeder/ SmartBowl is not charging
The pet feeder does not respond when plugged in nor does it show signs of charging.
Petnet app does not indicate device charging
Take out the metal tray from the SmartBowl to check for any charging errors. Power off the SmartBowl and then power it back on. Plug out the micro-USB cord and plug it back in. Now, on your Petnet app, check to see if your Smart Feeder is connected. The app should say “SmartBowl Online.” There should also be a battery symbol with a bolt inside of it to indicate that the device is plugged in and charging.
SmartBowl is not plugged in
The glowing white light on the front of the feeder lights up when the device is charging. If it not on, make sure that the device is plugged in. Check the wall plug to make sure that the micro USB is plugged into the wall plug and the device itself. Then, make sure that the SmartBowl is secure.
Battery is low
Your Smartfeeder may not be fully charged. Try to charge your device overnight in order to reach the maximum battery life. Check if the PetFeeder starts flashing lights. If there is no response to these steps, you may need to purchase a new micro USB cable.
12 pin connector is damaged
Your 12 pin connector may be damaged. Release the SmartBowl by pressing the button under the manual feed button and Petnet logo. Inside the Feeder Base, on the bottom right, are 12 gold connection pins.
If any of the pins are stuck or damaged, you can replace the 12 pin connector using our replacement guide.
Battery is faulty
The SmartFeeder has a lifespan of 8-10 hours when fully charged. If the device charge does not last this long, the battery may be faulty.
You can replace the internal battery using our guide.
SmartFeeder not dispensing food
Smartfeeder does not dispense any food into the bowl, even if the app is working normally
Food dispensing mechanism is broken
The SmartFeeder may have a broken internal dispensing mechanism. Refer to our
food dispensing wheel replacement guide to restore functionality to your SmartFeeder.
SmartFeeder is empty
Double check that there is food in the top basin of your SmartFeeder. Open the top of the basin and refill it with your selected food. Ensure that the food is dry kibble with a size of ⅛” to ⅝”, as other food may not be dispensed through the mechanism.
SmartFeeder is jammed
Pellets are stuck in dispensing mechanism
Some shapes of food pellets may become stuck behind the SmartBowl while the SmartFeeder is dispensing normally. Eventually, pellet buildup in this area can reach back into the dispensing mechanism and cause a jam. Petnet offers a ramp which supports the SmartFeeder at an angle. The ramp helps food slide into the bowl easier and prevents food build up.
Pellets are stuck to bowl
If there are food pellets stuck to your metal tray, Petnet recommends that you wash the tray with soap and water. They recommend washing every two to three days. Oily foods are more likely to stick to the bowl.
SmartFeeder displays multiple low battery warnings
Your Petnet App shows multiple low battery warnings.
SmartFeeder is not plugged in
Ensure that your device is plugged into a wall outlet for A/C power.
SmartFeeder USB cable is not plugged in
Ensure the USB cable is securely plugged into the feeder body. Check to see if there is no damage to the USB cable, you may need to purchase a new cable.
SmartFeeder bowl is not installed in body
Ensure that the bowl is securely pushed all the way into the feeder base. You can also charge the Feeder Bowl directly by removing the bowl from the base and accessing the USB port on the back of the bowl. Plug in the USB charging cable to the Feeder Bowl port and open you Petnet App. Go to "Device Page" and at the top of the page look for a green charging icon.
SmartFeeder is not connecting to wireless network
Your SmartFeeder has trouble connecting to your wireless network.
Your phone has firewalls in place
To connect your SmartFeeder to your wireless service, you must pair the SmartFeeder to your phone first. If your SmartFeeder has firewalls in place, they may prevent the SmartFeeder from properly connecting to your phone. Make sure you turn off any firewalls you may have enabled before attempting to connect the SmartFeeder to your phone.
Your phone is connected to a 5GHz network
To connect your SmartFeeder to your wireless service, your phone must be connected to a 2.4GHz network. 2.4GHz networks offer wireless service at a longer range, which is necessary for the SmartFeeder.
Your phone is not properly placed on the SmartBowl
To connect your Smartfeeder to your wireless service, your phone must be placed on the left side of the SmartBowl with the Petnet logo facing towards you. After clicking the “Connect” button on your phone, place it face down on the left side of the SmartBowl until the SmartBowl displays a set of green lights.
Kristin Villanueva
370 Reputation
2 Guides authored
Cal Poly, Team S13-G7, White Fall 2018 Member of Cal Poly, Team S13-G7, White Fall 2018
CPSU-WHITE-F18S13G7
4 Members
60 Guides authored
10 Comments
Hello I just bought a smart pet feeder and it says I need to remove the device first because other user already add the device.
Did master reset but still device is not removed.
Thank you for your help.
Ma SP - Reply Share
Hi. How your factory reset your SmartFeeder?
Serhii Korneiko - Reply Share
Hallo I have SmartFeeder for years, and suddenly, I cannot log in to my app I getting message an SSL error has occurred and secure connection cannot be made . also the feeder stop serving food, any suggestions
thenk you rene
oscar0474 - Reply Share
Hello, i’m having the same problem as oscar0474 — it appears that the PetNet server is down. but i thought that the whole point was that the device didn’t need internet access to feed. isn’t the feeding schedule saved locally, in case of power outages?
Frank - Reply Share
Yep, same problem as Oscar and Frank.
I have not been able to find avenues in correcting this issue. Very frustrating as this machine feeds three cats.
lksenderella - Reply Share
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 17
All Time: 7,460
