Petnet SmartFeeder SF10E Battery Replacement
    1. Petnet SmartFeeder SF10E Battery Replacement, Battery: step 1, image 1 of 3 Petnet SmartFeeder SF10E Battery Replacement, Battery: step 1, image 2 of 3 Petnet SmartFeeder SF10E Battery Replacement, Battery: step 1, image 3 of 3
      • Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
      • Remove the metal tray by using both hands and pulling out the bowl towards you.
      Ask FixBot
    2. Petnet SmartFeeder SF10E Battery Replacement: step 2, image 1 of 2 Petnet SmartFeeder SF10E Battery Replacement: step 2, image 2 of 2
      • Turn the bowl tray side down by using both hands.
      • Remove seven 11 mm screws by using the Phillips #1 screwdriver.
      Ask FixBot
    3. Petnet SmartFeeder SF10E Battery Replacement: step 3, image 1 of 2 Petnet SmartFeeder SF10E Battery Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Take the battery out of the SmartBowl with tweezers, avoid pulling on any wires.
      • Hold the SmartBowl down using one hand while using the other hand to remove the battery.
      Ask FixBot
    4. Petnet SmartFeeder SF10E Battery Replacement: step 4, image 1 of 2 Petnet SmartFeeder SF10E Battery Replacement: step 4, image 2 of 2
      • Remove the tape, closest to the four white connectors, with your hands.
      • Keep the wires attached to the tape for easy reassembly.
      Ask FixBot
    5. Petnet SmartFeeder SF10E Battery Replacement: step 5, image 1 of 2 Petnet SmartFeeder SF10E Battery Replacement: step 5, image 2 of 2
      • Trace the wires with your hands from the battery to the motherboard.
      • Detach the three-prong connector between the battery and the motherboard by pulling the white connectors with your hands.
      • Hold on to the sockets on the motherboard or you could accidentally pull off the entire assembly.
      Ask FixBot
Kristin Villanueva
370 Reputation
2 Guides authored
Cal Poly, Team S13-G7, White Fall 2018 Member of Cal Poly, Team S13-G7, White Fall 2018
CPSU-WHITE-F18S13G7
4 Members
40 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 34
All Time: 887
