Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Camera Won't Turn On
You've tried everything, but you can't turn it on.
Battery is Missing
Before starting to dismantle your camera, check to see if the battery is inserted into the battery port on the bottom of the camera.
Uncharged Battery
The battery may be uncharged. Try fully charging the battery, and insert again into the battery port.
Bad Battery
If the battery is inserted, but the camera still doesn't turn on, the battery may be dead, corroded, or defective. Consider buying a replacement battery.
Images are Blurry
Developed images are very blurry or distorted.
Dirty Lens
The lens may be dirty; try cleaning it with a lint-free cloth and rubbing alcohol.
Shaky hands
The pictures may not have been taken with a steady hand. Try holding the camera more still or place on a tripod for more stability.
Bad Film
The film in your camera may be defective. Try buying a different brand of film, or a new roll.
Broken Shutter
The shutter may be broken inside. You may need to perform a full replacement. These steps are explained in our Pentax PZ-10 Button Replacement guide.
Can't See Through Viewfinder
Viewfinder is dark, blurry, or you can't see through it at all.
Lens Cap is On
The lens cap may still be on. Try removing it.
Lens Not Properly Installed
The lens may not be properly installed. Make sure that the lens is tightly secured or oriented correctly.
Viewfinder Obstructed
There may be something stuck in front of the viewfinder lens. Try clearing it out with a cotton swab and rubbing alcohol.
Internal Components Damaged
The internal mirrors or shutter may be damaged. Consider replacing it here:
Shutter Isn't Working Properly
Shutter doesn't engage or make an audible sound when button is pressed, or you can hear grinding, or questionable noises.
Insensitive Button
The button on the camera may have dirty contacts. Try blowing compressed air through the crevices around the button, or swab the area with a cotton swab and rubbing alcohol.
Shutter Jammed
The shutter mechanism may be jammed by a small object. Open the back of the camera to see if there aren't any visible obstructions, and carefully dislodge them using tweezers or compressed air.
Shutter Damaged
The shutter may be completely damaged. Consider a complete replacement of the shutter.
Buttons Don't Work
Buttons don't fully depress, grind or stick when pressed, or simply doesn't activate the camera.
Buttons May Be Jammed
Check the crevices around the button, and see if there is anything lodged or residue in them. Try using a small thin object, such as a needle or spudger, to clear out these cracks, or blow compressed air through the surfaces.
Buttons Contacts May be Dirty
The buttons may have some residue over the contacts. Try swabbing the area with some rubbing alcohol and cotton swabs to clean the contacts.
Button May be Broken
The component may just be broken or faulty. Disassembly and replacement may be necessary. You can find the Pentax PZ-10 Button Replacement here.
Flash Does Not Activate
Flash does not engage when the flash feature is enabled, or the flash is weak.
Flash Switch/Button Stuck
The switch/button may be stuck or something is lodged in the spaces. Try the previous solutions for nonresponsive buttons listed above.
Flash Bulb Burned Out
The flash bulb may be burned out. A new bulb replacement may be necessary. Consult our guide for Pentax PZ-10 Flash Bulb Replacement.
Film Won't Load
The film may not load into the camera, or won't wind properly.
Faulty Film
The film may be faulty; check for any folds, kinks, or imperfections in the film. If any, discard the film, and try another roll.
Film Door Jammed
The film door may be jammed; a full seal is necessary for the film to load. Try checking the hinges for any obstructions, and apply the jammed button solutions listed above, or apply a lubricant to the axle on the hinge.
Film Gears Jammed
The gears may be jammed. Check the gear assembly for any visible obstructions. If none are visible, consult our How to clean the Pentax PZ-10 gears guide.
Back Cover Won't Open
The spring that pushes the door lock might need to be fixed or replaced. Consult our Pentax PZ-10 Back Cover Locking Switch Spring Replacement guide.
Victoria
64 Reputation
0 Guides authored
1 Comment
There's a little switch on the zoom lens, and it fell off a long time ago. I think I read at the time that it's a common problem. Can it be easily fixed?
Brad Rathernotsay - Reply Share
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 35
All Time: 3,402
