Pentax PZ-10 Button Replacement
Views: 1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
95
All Time:
1,012
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
Button replacement may be necessary if the shutter button sticks or no longer activates shutter due to wear.
Tools
    1. Pentax PZ-10 Button Replacement, Top Cover: step 1, image 1 of 1
      • The top cover is one piece encasing the top of the device except the shutter release button and flash.
      Ask FixBot
    2. Pentax PZ-10 Button Replacement, Removing Upper Right Housing Screw: step 2, image 1 of 2 Pentax PZ-10 Button Replacement, Removing Upper Right Housing Screw: step 2, image 2 of 2
      • With the camera lens face down, locate the screw under the overhanging piece of the top casing on the right side of the back panel.
      • Using the J0 screwdriver, remove the 6.3 mm screw.
      Ask FixBot
    3. Pentax PZ-10 Button Replacement, Removing Screw in Battery Compartment: step 3, image 1 of 2 Pentax PZ-10 Button Replacement, Removing Screw in Battery Compartment: step 3, image 2 of 2
      • Locate the next screw by holding the camera upside down with the battery compartment empty and face up.
      • Remove the 6.3 mm screw using a J0 screwdriver.
      Ask FixBot
    4. Pentax PZ-10 Button Replacement, Removing Screw Under Flash Bulb: step 4, image 1 of 2 Pentax PZ-10 Button Replacement, Removing Screw Under Flash Bulb: step 4, image 2 of 2
      • The next screw is found in the overhanging piece just above the lens.
      • With the top of the camera facing down, remove the 3.4 mm screw with a J0 screwdriver.
      Ask FixBot
    5. Pentax PZ-10 Button Replacement, Pulling Off the Top Cover: step 5, image 1 of 2 Pentax PZ-10 Button Replacement, Pulling Off the Top Cover: step 5, image 2 of 2
      • Gently pull off the top cover with your hands by pulling on the tab on the left of the camera.
      Ask FixBot
    1. Pentax PZ-10 Button Replacement, Locate Rubber Tabs: step 6, image 1 of 2 Pentax PZ-10 Button Replacement, Locate Rubber Tabs: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Gently remove the beige rubber tabs from under the casing by pulling each down using tweezers.
      Ask FixBot
    2. Pentax PZ-10 Button Replacement: step 7, image 1 of 1
      • Remove the 3 buttons by pushing them from under the casing out through the top.
      • Each button is slotted differently, so pay attention to the orientation of each piece.
      Ask FixBot
    3. Pentax PZ-10 Button Replacement, Buttons: step 8, image 1 of 1
      • The buttons are now free to be replaced or cleaned.
      Ask FixBot
Jonathan Diaz
213 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 95
All Time: 1,012
