Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Screen is Unresponsive Or Responds Without Touching
No matter where you touch the screen the device does not respond or it responds without you touching it.
Device May Be Over-Heated
Using the device for long periods of time could cause the device to freeze and not respond to simple commands. The device needs to be restarted. Hold power button on the top left of device to switch off.
Screen May Not be Aligned
Sometimes bumping the device or dropping it may shift parts inside the device and cause the screen to not respond. Realigning the screen can correct this issue. Following the steps in the Display Replacement Guide can provide a quick solution to this problem.
Screen is Dirty
It is possible that having a screen that is smudged could be causing this issue since there is interference between the screen and the user. Cleaning the screen and maintaining it can be the solution.
microSD Cards are Faulty
The microSD card is not working properly and interfering with the performance of the device.
Display Needs Re-calibrating
There are applications that can be downloaded to help with this issue. Re-calibrating the display can improve the performance of the device and improve the commands the user wants to execute.
Faulty Battery
Sometimes the battery may not be working correctly and be causing delay responses or no responses at all from the device. Charging the device can improve performance.
Battery Drains Quickly
The device is on for a short time and experiences drastic battery drainage.
Battery is Not Charging Properly
Battery may be damaged or old and needs replacement, in which case the Battery Replacement Guide can be used.
The Charger May be Faulty
In some cases, the device itself is not the problem and the charger needs to be replaced. Replacing the charger can correct battery drainage problem.
Device Does Not Power On
Battery is Not Fully Charged
Make sure charger is working and connected correctly to device to ensure proper charging.
Battery is Faulty
Battery may be damaged or old and needs replacement. Make sure that the battery if fully charged.
Broken Or Shattered Screen
A damaged or shattered screen can result in a number of problems such as a non-responsive screen, or action from device without a touch.
Screen Needs Replacing
The device screen may be beyond repair and can result in injury from the broken glass. It is recommended to replace the screen. The Display Replacement Guide offers information on how to change the screen.
Speaker is Non-Responsive
When trying to use the speakers there is faint sound, or no sound emitted from the speakers.
Volume Buttons Are Faulty
The buttons may be damaged or stuck and need replacing, forcing the device to play faint or no noise. The Button Replacement Guide can be helpful in fixing this problem.
Speaker Is Faulty
The speaker may be damaged and the only solution for expected sound quality would be to replace the speakers using the Speaker Replacement Guide
Buttons Are Not Responsive
You try to use the volume, power or home buttons but they do not respond or become stuck.
Buttons Are Jammed
Over time, buttons may be overused and need replacing.
Defective Connection
The buttons may not have a great connection to the device and need to be readjusted.
Author
with
Maria Delpilar
335 Reputation
1 Guide authored
USF Tampa, Team 11-5, Blackwell Winter 2015 Member of USF Tampa, Team 11-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G5
3 Members
84 Guides authored
9 Comments
my nook color will not turn on, when I try turning it on I will see a fast white flash on the screen but It will not turn on, nothing works in it. Could this be a bad battery?
ogie666 - Reply Share
My nookcolor gets stuck in a page loop when reading certain books. It’s like a 5 page loop that it won’t pass. Any ideas?
Sue Cabot - Reply Share
my nook color keeps showing network problem and cannot access my content
jojo labaire - Reply Share
Does anyone else have issues with web crashing all the time, apps do not show up and can barely do anything besides read? If it is an update issue how do I fix it when updates do not seem to show either I get network errors when my wifi is fine?
Model: BNRV200
Chris Dunphy - Reply Share
How to make the nook unfreeze on the setup menu
Ricky Samson - Reply Share
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 32
All Time: 7,326
