Up to 20% off select tools
Nook Color Battery Replacement
Views: 4K
View statistics:
Past 24 Hours:
7
Past 7 Days:
31
Past 30 Days:
121
All Time:
4,009
Comments: 0
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
Introduction
Go to step 1 ↓
Be cautious when removing the back panel of the device. Buttons tend to become loose and fall out of place. Some force is necessary in removing the back and front panels.
    1. Nook Color Battery Replacement, Back Cover: step 1, image 1 of 2 Nook Color Battery Replacement, Back Cover: step 1, image 2 of 2
      • Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
      Ask FixBot
    2. Nook Color Battery Replacement: step 2, image 1 of 2 Nook Color Battery Replacement: step 2, image 2 of 2
      • Pry off the back cover with the plastic opening tool. Go around the device with the tool to ensure complete detachment.
      Ask FixBot
    1. Nook Color Battery Replacement, Front Cover: step 3, image 1 of 1
      • Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
      Ask FixBot
    2. Nook Color Battery Replacement: step 4, image 1 of 2 Nook Color Battery Replacement: step 4, image 2 of 2
      • Pry off the front panel using the plastic opening tool.
      Ask FixBot
    3. Nook Color Battery Replacement: step 5, image 1 of 2 Nook Color Battery Replacement: step 5, image 2 of 2
      • Lift up on the connectors to disconnect them using the plastic opening tool.
      Ask FixBot
    1. Nook Color Battery Replacement, Battery: step 6, image 1 of 2 Nook Color Battery Replacement, Battery: step 6, image 2 of 2
      • Remove the tape which holds the wiring to the battery using a plastic opening tool.
      Ask FixBot
    2. Nook Color Battery Replacement: step 7, image 1 of 3 Nook Color Battery Replacement: step 7, image 2 of 3 Nook Color Battery Replacement: step 7, image 3 of 3
      • On the back side of the middle panel, pry the battery using the plastic opening tools.
      • Use of force is necessary since the battery is glued down.
      Ask FixBot
    3. Nook Color Battery Replacement: step 8, image 1 of 2 Nook Color Battery Replacement: step 8, image 2 of 2
      • Slide the connecting wire through the opening of where the battery was placed.
      Ask FixBot
6 other people completed this guide.
Author
with
John Goly
595 Reputation
3 Guides authored
USF Tampa, Team 11-5, Blackwell Winter 2015 Member of USF Tampa, Team 11-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G5
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 31
Past 30 Days: 121
All Time: 4,009
