Nokia 5310b Troubleshooting
Back to Device Page
Phone Won't Turn On
No matter what you do, you can't get your Phone to turn on.
Hold Switch On
Before delving into the guts of your Phone, hold down the power button on the top of the phone to verify that it is unresponsive.
Drained/Bad Battery
If your Phone won't turn on, it may be due to a dead or bad battery. Plug the phone into a power source to test if the batter is dead. If your phone is still unresponsive, you may need a new battery. To view the iFixit battery repair guide click here You can also purchase a new battery from a nearby retailer.
Battery Won't Charge
Even if you plug the Phone into an outlet, the battery will not charge.
Bad Connection
If your Phone will not charge, this may be due to a faulty connection.
  • Check that the charge cable is firmly inserted into the Phone. Check inside the of the charging port of the Phone to verify that there is no dirt or gunk that would cause a bad connection.
  • Also check that the outlet is working and that the charger is firmly plugged into the outlet.
Battery is Not in Phone
Check that the battery is in the back of the phone and that it has been inserted correctly.
Phone Won't Turn Off
No matter what you do, you can't get your Phone to turn off.
Frozen Screen/Buttons
If the screen and buttons are frozen on the phone and it is unresponsive, try removing the battery, then replacing it and pressing the Power On button on the top of the phone.
To view the iFixit LCD screen repair guide click here
To view the iFixit Keypad repair guide click here
Restore Factory Settings
To restore your phone to its default settings, select MENU > SETTINGS > Rest. Factory Sett. Choose one of the following:
  • Restore Settings Only - resets preference settings without deleting personal data
  • Restore All - resets preference settings as well as deletes all personal data (ie. Contacts, Media Files, etc.)
No Media Audio
Faulty Headphones
It is possible your headphones are broken and need to be replaced.
Headphone Jack
There could be a bad connection between your headphones and the headphone jack. Try cleaning out the headphone jack with a Q-tip.
Back to Device Page
Author
with
Max Kirby
518 Reputation
4 Guides authored
Cal Poly, Team 15-14, Regan Spring 2011 Member of Cal Poly, Team 15-14, Regan Spring 2011
CPSU-REGAN-S11S15G14
3 Members
48 Guides authored
3 Comments
How to change the loudness of Nokia 5310 mobile phone ? The volume of loudness becomes too low to hear anything . Please guide .
Atindra Pal - Reply Share
I cannot hear people but they can hear me
marg.walsh.01 - Reply Share
How to eliminate password??
Alfredo - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 26
All Time: 4,823
