Nokia 5310b XpressMusic LCD Screen Replacement
  1. Nokia 5310b XpressMusic LCD Screen Replacement, Battery: step 1, image 1 of 1
    • Slide the black battery cover down and off the phone with your thumb to remove it.
    • The battery cover is not shown in this picture
    Ask FixBot
  2. Nokia 5310b XpressMusic LCD Screen Replacement: step 2, image 1 of 2 Nokia 5310b XpressMusic LCD Screen Replacement: step 2, image 2 of 2
    • Gently lift the battery with a fingernail to remove it from the back of the phone.
    • Keep the battery removed for the next steps
    • The battery may be replaced or repaired at this step.
    Ask FixBot
  3. Nokia 5310b XpressMusic LCD Screen Replacement, Keypad: step 3, image 1 of 3 Nokia 5310b XpressMusic LCD Screen Replacement, Keypad: step 3, image 2 of 3 Nokia 5310b XpressMusic LCD Screen Replacement, Keypad: step 3, image 3 of 3
    • On some models, the front case is screwed down from the back. Follow steps 5 and 6 first to remove the camera cover and two T6 screws, BEFORE removing the faceplate.
    • Find a small latch under the music keys and in the middle of each side of the faceplate.
    • Gently lift the edges of the front faceplate off the phone using a spudger.
    Ask FixBot
  4. Nokia 5310b XpressMusic LCD Screen Replacement: step 4, image 1 of 2 Nokia 5310b XpressMusic LCD Screen Replacement: step 4, image 2 of 2
    • Flip the phone over to the front side.
    • Lift up the keypad from the bottom with either a spudger or your finger.
    • At this time the keypad can be removed and replaced.
    Ask FixBot
  5. Nokia 5310b XpressMusic LCD Screen Replacement, Motherboard: step 5, image 1 of 1
    • Flip the phone over to the back side.
    • Unsnap the back camera cover from the phone.
    • Lift to remove the back camera cover from the phone after it has been unsnapped.
    Ask FixBot
  6. Nokia 5310b XpressMusic LCD Screen Replacement: step 6, image 1 of 2 Nokia 5310b XpressMusic LCD Screen Replacement: step 6, image 2 of 2
    • Remove the two screws on either side of the camera with the T6 Torx screwdriver.
    • Remove the 4 screws located at each corner of the white keypad base using the T6 Torx screwdriver.
    Ask FixBot
  7. Nokia 5310b XpressMusic LCD Screen Replacement: step 7, image 1 of 1
    • Unclip the faceplate plug (ribbon) located in the lower left corner of the motherboard.
    Ask FixBot
  8. Nokia 5310b XpressMusic LCD Screen Replacement: step 8, image 1 of 2 Nokia 5310b XpressMusic LCD Screen Replacement: step 8, image 2 of 2
    • Use a spudger to gently pry the two metal clips in the middle of the left and right sides of the motherboard slightly to provide enough room to lift the motherboard out.
    • At this point the phone should come apart into two pieces (the motherboard/LCD screen and the faceplate).
    Ask FixBot
  9. Nokia 5310b XpressMusic LCD Screen Replacement, LCD Screen: step 9, image 1 of 1
    • Unclip the ribbon plug located on the top of the LCD screen that connects it to the motherboard.
    Ask FixBot
6 other people completed this guide.
Max Kirby
518 Reputation
4 Guides authored
Cal Poly, Team 15-14, Regan Spring 2011 Member of Cal Poly, Team 15-14, Regan Spring 2011
CPSU-REGAN-S11S15G14
3 Members
12 Guides authored
1 Guide Comment
Thank you much! As efficient & thorough as it gets!
REDACTED FREE PRESS - Reply Share
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 36
All Time: 9,883
