Pro Controller Does Not Turn On
No matter how many times I try to connect or sync my controller, it will not turn on.
Low Battery
Your battery level may be low. If the battery is low, the controller cannot connect to the console. Charge your battery.
Pro Controller won't sync with Wii U Console
I want to navigate my Wii U, but my pro controller refuses to connect or will not stay connected.
Period of Inactivity
After some time of inactivity, the remote will turn off and you will need to turn the remote back on.
Low Battery
Your battery level may be low. If the battery is low, the controller will not turn on. Try charging your battery.
Charging Cable
If, when plugged in, your device does not charge, then you may have to buy a new cable.
Sticky Buttons (A,B,X,Y, Power, Home, Select, Start, Sync, R, L, ZR, ZL)
One or more of the buttons on my controller will not return to depressed position as quickly as usual.
Residue/Debris Accumulation
The buttons may have accumulated debris that is limiting proper function. See how to remove and replace these buttons in our Buttons Replacement Guide.
Nintendo Wii U Pro Controller ABXY Buttons Replacement| Buttons Replacement Guide
Troublesome Thumbstick
I cannot properly navigate my Wii U.
The buttons may have accumulated debris that is limiting proper function. See how to remove and replace joysticks in our Joy Stick Replacement Guide.
Controller Won't Vibrate
While engaged in gameplay, my Wii U Pro Controller does not vibrate.
Vibration Function Not Enabled
Make sure your vibrations setting is enabled. This can be done in the settings of the game you are playing.
Low Battery
If your battery is low, the controller may not vibrate in order to save battery life. Charge your controller.
Vibration Motor is Defective
If you have exhausted all other possible solutions, it may be that the vibration motor is malfunctioning.
Author
with
Chris Felder
153 Reputation
1 Guide authored
IUPUI, Team 2-2, Harley Fall 2015 Member of IUPUI, Team 2-2, Harley Fall 2015
IUPUI-HARLEY-F15S2G2
4 Members
60 Guides authored
3 Comments
I have a wii remote for a second player
I have syn it with my controller and desk box where the game go in
It's said hit +which I did but it won't start/connect
sexxytash69 - Reply Share
What if my pro controller keeps pressing the sync button by itself
i am not pressing it and it acts if I did press it
Evan Yeet - Reply Share
The charging indicator is on when plugged in, but the controller itself doesn't turn on.
Zack M - Reply Share
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 53
All Time: 8,979
