Nintendo Wii U Pro Controller Joystick Cover Replacement
  1. Nintendo Wii U Pro Controller Joystick Cover Replacement, Battery: step 1, image 1 of 1
    • Turn the controller over to reveal the battery cover.
    • Use the J000 screwdriver to remove the screw that secures the battery cover.
    Ask FixBot
  2. Nintendo Wii U Pro Controller Joystick Cover Replacement: step 2, image 1 of 2 Nintendo Wii U Pro Controller Joystick Cover Replacement: step 2, image 2 of 2
    • Remove the battery from the controller by inserting the plastic spudger into the small gap on the bottom right of the battery.
    • Use the spudger as a lever to pry up and remove the battery from the compartment.
    Ask FixBot
  3. Nintendo Wii U Pro Controller Joystick Cover Replacement, Joystick Cover: step 3, image 1 of 1
    • Remove the eight 5.5 mm Y0 screws.
    Ask FixBot
  4. Nintendo Wii U Pro Controller Joystick Cover Replacement: step 4, image 1 of 2 Nintendo Wii U Pro Controller Joystick Cover Replacement: step 4, image 2 of 2
    • Now that you have removed all of the screws, carefully separate and remove the bottom half of the controller shell from the top half.
    • If you feel any resistance when pulling the shells apart, use a spudger to separate the left and right trigger contact assemblies from the bottom shell.
    Ask FixBot
  5. Nintendo Wii U Pro Controller Joystick Cover Replacement: step 5, image 1 of 1
    • Move the right trigger and sensor out of the way.
    • Remove the 4 mm JIS #0 screw.
    Ask FixBot
  6. Nintendo Wii U Pro Controller Joystick Cover Replacement: step 6, image 1 of 1
    • Move the left trigger and sensor out of the way.
    Ask FixBot
  7. Nintendo Wii U Pro Controller Joystick Cover Replacement: step 7, image 1 of 1
    • Remove the joysticks and motherboard from the controller’s shell.
    Ask FixBot
  8. Nintendo Wii U Pro Controller Joystick Cover Replacement: step 8, image 1 of 1
    • Carefully pull the rubber thumbsticks off of the electronic bearings to remove the joysticks.
    Ask FixBot
Finish Line
11 other people completed this guide.
Jesse Burton
628 Reputation
3 Guides authored
IUPUI, Team 2-2, Harley Fall 2015 Member of IUPUI, Team 2-2, Harley Fall 2015
IUPUI-HARLEY-F15S2G2
4 Members
15 Guides authored
1 Guide Comment
Where can I buy those Nintendo wii u pro controller analog joystick prints? I can only find them for the wii u Gamepad on ebay.
Thx for a good guide!
Simon Denmark
Simon Martin Sørensen - Reply Share
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 102
All Time: 11,704
