Introduction
Working ABXY buttons are important elements needed to ensure smooth gameplay for any gaming system. For the Wii U Pro Controller, debris and residue is likely to build up underneath the buttons, which can slow down the responsiveness of the buttons and even cause them to stick. In this guide, one will learn how to break down the controller in order to access the underside of the buttons, where cleaning will take place to restore the buttons back to their original functionality. In order to get to this point, it is recommended that you take a look at the two previous guides regarding the controller’s battery replacement and joystick replacement.
Turn the controller over to reveal the battery cover.
Use the J000 screwdriver to remove the screw that secures the battery cover.
Now that the joysticks are removed, locate the screws on the left and right side of the controller (highlighted in the photos) and use the J0 bit to remove these 4 mm screws. This will allow you to pull out the controller board
Once these two screws have been removed, you may go ahead and remove the board from the controller housing. Now, direct your attention to the front panel of the controller. Remove the buttons and wipe them down completely with rubbing alcohol and a q-tip. Set them aside to dry for several minutes.
To reassemble your device, carefully follow these instructions in reverse order.
6 other people completed this guide.
1 Guide Comment
Thanks so much! I spilt milk on my controller and got the buttons all gummed up but this guide helped me clean them up, including dust and the gunk inside of it, you saved me a ton of money!
